Introduction: Mini Arduino CNC
This instructable shows you how to build a cheap and easy, but very small CNC using Arduino UNO. You can use it to mill thin wood, different foams or you can use it for plotting different sketches and also can be used for engraving and etching purposes.Inspired by the Small Arduino CNC (thank you very much for your help), i made it easily.
PARTS YOU NEED:
For this project you will need:
3 old CD/DVD-Roms
1 Computer power supply
3 Easydriver boards
1 Arduino Uno
2 pieces of Wood
1 Soldering Iron
1 Soldering Wire
Step 1: Demo Video
Demo Video 1
Thanks to everybody who voted me for the contest and I am very glad that i have won 2 contests :D
UPDATE:
Watch the new video of this mini CNC plotter. I have increased the feed rate for sketching. I was using Deskengrave and many other softwares just to check the working of the machine, the results was not satisfactory because some Gcode generated codes were not supported by the GRBL library. After searching n the internet i found Inkscape software. Inkscape is a free and open-source vector graphics editor; it can create or edit vector graphics such as illustrations, diagrams, line arts, charts, logos and even complex paintings. By using this software i can import Dxf, Dwg, JPG, SVG etc files and can convert them into GCODE. You can download Inkscape by clicking below link.
Download Inkscape
I have import several image files which i had downloaded from the google, convert them into Gcodes and send to the GRBL software, it worked perfect :D. Below is the link of sample video i have just made.
Demo Video 2
How to use Inkscape?
There are alot of videos on youtube which will guide you to how to use this software and generate Gcodes. For quick guidance see this link.
Inkscape and Serial Transfer
Step 2: Using the DVD CD-ROM, Get Stepper Motors
I took three wasted DVD-drives apart because we need the steppers (XYZ axis)
Step 3: Step 3: Assemble and Build the Structure
For this part just need a base platform and two pillars. I made the base from wood and pillars are of aluminum. Now simply screw the wooden base withe your Pillars as shown in first Figure.
Place the X axis across the pillars and Y axis onto the wooden base as shown in figures.I used glue to assemble all the axis. Just make sure that all the axis are exactly perpendicular to each other, they must be at right angle.
Step 4: Step 4: Soldering and Wiring
This is also not a very complicated step. You just need to solder wires with your stepper motor. Be careful while soldering and don't use high watt solder as it can burn the wires of stepper, mine was 30W and it was OK. After that, simply sold all the connectors in easydrivers and connect the wires as given in figure.
Step 5: The Software
1. Download and install the Arduino Software, the grbl library and the Grbl controller. or goto the link below
http://blog.protoneer.co.nz/quick-grbl-setup-guide-for-windows-arduino-g-code-interpreter/
2. After downloading the Grbl library, you have to click sketch --> import library --> add library in the Arduino software and select the zip file you just downloaded.
3. Upload the library to your Arduino.
4. After you installed Grbl on your Arduino open the Grbl controller and select the port to which your Arduino is connected. Press the open button.
5. A list of options appears in the command screen. You have to change a few of these options, by entering the number of the option (the numbers with a $) = and the new value (For example $130=35.000).If your motors are moving into the wrong direction, go to Tools --> Options --> Axis and click the axis you want to invert.
6.You can use any Gcode Generator software to make gcodes.I download DeskEngrave software which is also a gcode generator, here is a link deskEngrave
Step 6: Thank You, Instructables!!
It is really very easy project if you want any help you can ask anytime.
I really want to thank INSTRUCTABLEs and all the people here sharing their ideas. Following this platform i am really able to make my own projects very easily :D :D :D
Second Prize in the
Automation Contest
Runner Up in the
3D Printing Contest
Explore Science Contest
8 People Made This Project!
- me_zain made it!
- TonyH3 made it!
- maulvio made it!
- AbderrahimA made it!
See 4 More
120 Comments
Question 10 months ago
i wen to web site you recommend http://blog.protoneer.co.nz/quick-grbl-setup-guide-for-windows-arduino-g-code-interpreter/
there is also 3 thing to download,
1. grbl
2. xloader
3. universal g code sender.
but i can't download xloader, when i go the link to download xloader,
weird site (http://ww12.russemotto.com/) is open.
so i can't get xloader .....
hwo can i ????
hello, i want to download grbl controller , so i clicked down grbl controller,
and then error web page is open , that says google drive's page, there is no file you request.
so, i make my google drive app.
but after making my google drive app, i can't still open the grbl controller page.
how can i get a grbl controller ?
1 year ago
For an easy tool chain, you may use GRBL-Plotter: https://github.com/svenhb/GRBL-Plotter
Example: https://grbl-plotter.de/index.php?id=micro-plotter...
4 years ago
Hi.when i uploading gcode file in grab controller or another software to send gcod to machine and chooseing begin i receiving this error [buffer size too small process interrupted ]pls give me solution.
4 years ago
If any one have cnc Machine for sale contact with me
Reply 4 years ago
5 years ago
Please help me. I don't have $14 and can you post a printscreen with lower commands $1 , $2 , $3 . Thank you . You will help me alot
5 years ago
Hey i did all of this and when i load a gcode on grbl it doesn't work. It only moves slow in the air abou 5 mm. Do i need to fine tune the cnc or something ? If so how ? Please help. Thanks
Reply 5 years ago
HI..
Have to check/edit your settings in grbl software according to your belt/lead screw pitch as shown in figure?
Reply 5 years ago
Thanks for the reply mate. The settings are the same as yours. I don't know what is the problem. Are there any other fine tune or something ?
Reply 5 years ago
I don't have the $14(autostart bool) option. Do i need to do something to appear ?
5 years ago
can anyone send me grbl controller. the link given in disable.
uzairsamisoomro@gmail.com
Reply 5 years ago
Sorry for the late reply, I was really busy coudnt find time to reply early.
I have just sent you grbl controller setup in email. Check your email.
5 years ago
hi bro help me i am try to making this project but sam problem create my stepper motor not working but normal motor is working please help me
my whastp no is 9958589245 please contact me
Reply 5 years ago
what is your error/problem?
5 years ago
Well after about 3 hrs of searching and trying to find a solution, my last resort is to write here. The grbl library doesn't work fro me (as mentioned by someone else) I keep getting the folder does not contains a valid library, then I tried the GRBL-Arduino-Library-master that some one else suggested, that one does loads but when I try upload it to the board I get a compiling error. I just cant find how to run it. Any help is appreciated. Tnx.
Reply 5 years ago
Got to the link below and follow the steps.
http://blog.protoneer.co.nz/quick-grbl-setup-guide...
I think the new version of Arduino is not competible with the old files/library of GRBL because now for new CNC machine, I am also getting an upload error.
5 years ago
nice instructable sar ... sar I have a small doubt can we make plotter draw images of us
Reply 5 years ago
Yes it can plot Images too..
5 years ago
hey man i just got one problem ,whenever i used inkscape to convert g-code and upload or put in the grbl controller, its doesn't work always says, runtime error :scribbed version buffer size is too low and then it stopped , so what should i do now ?
