Introduction: Mini Beanbags for Mini Cornhole
Today I will be showing you how to make mini beanbags.
Step 1: Supplies You Will Need
First is the fabric, for the fabric I have gamecock and black fabric. Then the thread, for the thread I will be using black and white thread. Then you can either hand see or if you have a sewing machine then you can use that. I have a brother sewing machine that I will be using. For this you will also need scissors, needles, and lentils.
Step 2: Starting the Beanbags
First you will need to cut a piece that is 4 inches by 1 1/2 inches and you make as many as you want but I will be making 2 of each fabric. Then you are going to fold them in half but inside out. Then you are going to get your thread ready. It does not matter which fabric you use first if you are using 2 different fabrics.
Step 3: Sewing the Beanbags
First what you are going to do is sew the first 3 edge’s but to where you have an opening to put the lentils in. Then you are going to turn the right side out.
Step 4: Adding Lentils and Finish Sewing
You can use lentils or anything to fill the beanbags but I preferred to use lentils.
I poured some lentils into a bowl. Now it is time to put the lentils in the beanbags. I would fill it about half so you have room to do the rest. You will need a needle to hand sew this part. We are going to fold in the extra fabric. Now we will hand sew it. Make sure to tie a knot at the end of the thread. I would suggest that you have your thread at least 1 ft. long. Now that you have them all sewn you can play with them and have fun with them. Thanks for reading this instructables with me.
