Introduction: Mini Cardboard Remote Control Car
In This Instructables Session We are going to see How to make Simple Remote ControL Car
Step 1: Components Required:
For Making mini Cardboard RC Car
1) 1 Cardboard Rectangle Shape Piece (3.5*6.5)cm
2) 4 Cardboard Wheels (2cm Diameter) In Compass take 1 cm To make this circle
3) Mini Gear ( I took from old low expensive Made Drone)
4) Mini Brushed Motor ( I took From same Old Drone)
5) Mini Reciever Circuit (I designed using tinker cad and made it simple Circuit ( TSOP 1738 IR Reciever ), (45uF Capacitor You can 10uF to 100uF Capacitor) and (BD140 PNP Transistor))
6) Tooth Pick
7) 9 V battery (First is used mini 3 V Battery Which is not enough to pull the car . Then I used 9 Volt battery)
Step 2: Designing
I Made simple model By Using Tinker Cad
Step 3: Connect Gear With CardBoard
1) First Motor With Mini Gear
2) Cut a small portion of cardboard to fix the motor gear
3) Apply Some Hot glue on cardboard and attach the motor gear
Step 4: IR Reciever
1) I made a simple circuit By Using TSOP 1708 IR Reciever and 45uF Capacitor and a BD150 PNP Transistor . and Tested By tinker Cad Stimulation ( Check The circuit Before making into circuit For That I Used TinkerCad)
2) Then I made Small Circuit
3) And Connect Battery and motor with the circuit
Step 5: Connecting Wheel
Connect 4 Wheel To Remote Control car
I Connected two wheel To Motor Gear
And other two wheels I connected using 1 tooth pick
