Introduction: Mini Cooking Pot
In this instructables, you can use coke can How to make a
miniature pot.
Using coke can, wood chips and resin. Make your own small
pot.
Step 1: Cola Can Cutting
Cut the middle of the coke can
Grind the upper part of the lid with sandpaper
After removing the lid, grind the bottom of the lid again
Leave only the ring part as you can see the picture.
Step 2: Making the Pot Body
Combine the top and bottom of the already cut can into one.
Step 3: Make the Pot Lid (1)
Prepare the underside of a completely used gas cylinder.
Pour resin and resin hardner in proportion
Step 4: Make the Pot Lid (2)
Drill a hole in the center of the removed lid and attach
the decoration.
Step 5: Making a Pot Handle (1)
Makes the middle of the bent stainless steel straw flat
Cut the upper part of the straw and make a hole.
Step 6: Making a Pot Handle (2)
Cut a piece of wood to fit the size
Make a hole for a straw in the middle of a piece of wood.
Put the straw in the prepared wood to complete the
handle
Step 7: Assembly and Completion
Finally, connect the handle to the pot body and you are
done.
