Introduction: Mini Crossbow,
the end result.,,,
Step 1: Mini, Crossbow,,,
what you will need
7 standard sized lolly pop sticks
1 jumbo lolly pop stick
cutters
super glue
2 hair clips as shown in the pics
about 8 inches of string, i use stripped para cord
saw
some thread
and round shaped stick
Step 2: Glue the Edges.,,,
get 2 sticks and super glue the edge of one stick
then
Step 3: Grab 2 Sticks.,,,
hold the 2 sticks together
until bonded
Step 4: Add the Stick Down the Middle,,,
now grab another stick
run super glue down the face of the stick
and press it onto the other 2 sticks
making sure it is pressed down the middle of the other 2
Step 5: Join the 2 Together,,,
now do exactly the same with
the other 3 sticks
then super glue the face of the stick that runs down the middle of the 2 sticks
press tightly bonding the 2 middle sticks
Step 6: The Picture,,
the picture shows how it should look upto now
now at either end measure 1cm
mark it & then cut it at either end.
Step 7: Cut the Jumbo Lolly Pop Stick,,,
grab your cutters and the jumbo lolly pop stick.
cut the rounded ends off
then cut 2 pieces of 2 &1/2 inch
grab the 2 hair clips
add wood glue or use a glue gun
and grab 1 hair clip click or pop it onto the other side
grab the metal in the middle and with some manipulation the metal will snap off (they snap very easily)
then add glue to the bigger end of the hair clip
then press and hold the glued end onto the end of 1 of your 2 & 1/2 inch pieces of lolly pop stick.,,
Step 8: Do the Same ,,
do the same to the other end of your 2 & 1/2 inch piece of stick
now grab your other stick and do the same
glue and press it
so the hair clips look like they are sandwiched.,,,
now super glue one end of the rails.
to the limbs ( a word used in crossbow,meaning the bit where the string attaches )
Step 9: Add the String,,
now grab your string
and push it through the small holes which are already there
pull the string until its near the end
then tie a small knot
do the same at the other end
Step 10: Super Glue the String,,,
super glue the string
as this makes the string alot more stronger
after that
pull the string back as far as it will go
make a pencil mark where the string reached
and at an angle carefully saw the wood where the pencil mark is
do this both ways.
as in the pic above you want a v shape.,,
Step 11: Fair Play to You,as This Is the End,,,
now just infront of the v shape
saw straight down
until you reach no further than the second layer
then cut at a slight angle , upto the straight down cut
this will be the string holder.,,,
now taking your round shaped stick
lay it in the v mark and then cut off the unwanted bit
now super glue the round stick piece in to the v
with your last stick cut as shown in the pic ,the shape of a cricket bat
this will be the trigger
hold the bat shaped stick on the glued round bit
grab some thread and you want to cris cross this to hold the trigger in place add super glue to the thread.,,
and thats it folks
please stay safe,wear protective clothing
and happy hobbying.,,
