Introduction: Mini Dryer
This is my first instructable. i made this Mini dryer project it's because it will help us people to dry any mini clothes, handkerchief, under wears, and many mini stuffs. It is so easy to do because all parts that I used are all recycled. I hope you like it. :)
Step 1: Step 1:Materials
* bottle of 1.5 softdrinks
*water host
*charger
*switch
*electric tape
*instant glue
*styro foam
*hobby motor
*supporter for hobby motor
*baker's bunch tupperware (optional)
Step 2: Step 2: Prepare All the Materials
*Cut the 1.5 bottle in a half and put some holes in it and in the center of the bottle underneath put a small hole.
*Attach the switch in the baker's bunch tupperware and put some holes in tupperware beside the switch.
*Put some holes underneath on the opposite direction where you attach the switch.
*Use intant glue to attach the hobby motor to its support.
*Cut the stryrofoam according to the shape of your baker's bunch tupperware.
*Put a hole in the middle of the tupperware so that there is a way where the wire will go through.
Step 3: Step 3: Combining All the Material to Make a Mini Dryer
*Use instant glue to attach the small hole underneath the 1.5 bottle in the tip of the hobby motor.
*Put the attach hobby motor and 1.5 bottle in the middle of bakers bunch tupperware.
*Connect the charger and switch to put its wire in the hole that you made underneath the bakers bunch tupperware and connect the wire in the hobby motor.
*Put electric electric tape in all the wires to prevent ground and put a cover in the switch that you attach inside the tupperware so that the wires will not be shorten..
*And position the water host underneath the tupperware so that there is a flow of water .
*And lastly, position styrofoam over the baker's bunch tupperware and it will be the cover of our dryer.
Step 4: Step 4:Optional
You will notice some materials are hard to find don't worry all material are optional . You can use your own material to build this mini Dryer.:)
Step 5: Step 5:Apologizing
Sorry for me having a wrong grammar .. :)) thank you
