Introduction: Mini Egg Pi(e)
Given up sweets for Lent? On the Atkins diet? Still craving pie? This savory mini pie is perfect for you---and all other non-vegans. It's a beautiful, quite simple, morning treat that barely takes 3.14 minutes of effort to make!
Inspiration:
I was inspired by a link my friend sent me to make eggs in onion rings. Then I had the bright idea that I could use the end of the onion and turn it into a pi(e) for this contest. When I saw this reddit post wanting more directions, I knew I better act soon before the internet community scooped me!
Inspiration:
Step 1: Ingredients
Ingredients:
1 egg
1 onion slice
oil
salt and pepper
1. Slice the onion towards one of the ends so that it forms a small bowl. This will be your "pie crust"
I successfully used the medium and large slice in this photo. The small slice would not have contained an entire egg.
The salt and pepper will be for the topping. You could substitute cayenne pepper, curry powder, rosemary, or other spices.
1 egg
1 onion slice
oil
salt and pepper
Step 2: Onion Crust
1. Pour a small amount of oil into the pan to keep the onion from sticking.
2. Turn burner on at low-medium heat.
3. Place the onion in the pan with the large circle touching the pan.
4. Cook for about 2 minutes until the bottom of the onion is turning slightly brown.
5. Flip the onion over so that you will be able to crack the egg into it.
People aren't kiddng when they say cooking times vary by oven. I have a gas stove that heats quickly. You don't want your burner turned on so high that the oil is splashing out of the pan. It's pretty obvious when the bottom has turned brown.
Step 3: Adding the Egg Filling
1. Crack the egg into the onion
You may choose to try to remove the white above the yolk with a paper towel or fork. This makes the yellow more noticeable on the top of the finished product.
Step 4: Cook Egg
1. Add a teaspoon of water to the pan and place a lid over the pan.
If you do not use the lid method, it takes a long time for the egg to cook. The lid and water are highly recommended so that the bottom doesn't get overdone.
2. Continue heating over low-medium heat for about 5-6 minutes, until the top of the egg white has changed to opaque white and looks done.
3. Remove egg from pan.
There may be a little egg that leaks out of the onion crust. When I scoop the onion out of the pan, the small amount of egg white that spilled stays in the pan and the egg pi(e) is ready to plate.
Step 5: Plate the Pi(e)
1. Place pi(e) on plate and add cracked pepper and salt to the top.
