Introduction: Mini Farm With Solar Powered Wind Mill
This instrucable will show you how to build a cool, solar powered, wind mill.
In this build, I’m using pomegranate seeds but you can use whatever you want. I also show you how to de-flesh the pomegranate seeds if that’s what you choose to use.
Step 1: The Body
In this step I will explain what materials you will need, as well as how to make the body of the wind mill.
Materials:
.1 thin wood sticks (you can use skewers)
.2 duck tape
.3 small blades
.4 small motor
.5 small solar panel (I got mine from a solar powered van car)
.6 glue gun
.7 pot or something to put your dirt into
.8 potting soil
Then all you need to do is form the sticks into a triangle shape and then tape the top.
Step 2: Adding the Prongs
Now you need to cut two small prongs from the skewer and place it between the sticks
Step 3: Tape
Now just add tape over the sticks to hold it into place.
Step 4: Motor
Now just put the blades on the motor and glue it on the top of the sticks.
Step 5: Solar Panel
Now put the wires on the metal part of the solar panel. Hold them with small pieces of tape
Step 6: Solar Pole
Now tape the solar panel with the motor to a stick.
Step 7: Time to Pot
Now just put the wind mill in a pot with dirt and push it down a little.
Step 8:
Step 9: Planting
Make 2-3 lines in the dirt and place the seeds i in the lines spaced apart. Dropp some water on them then your done! Congrats on your new solar farm!
4 years ago
Fun project.
