Introduction: Mini Electronic Detonator
This inscrutable will show you how to make a simple yet effective electronic ignition system.
BTW, first instructable! :)
For this instructable you will need:
1. Switch.
2. Push Button (I ONLY HAD TWO SWITCHES)
3. LED (don't have one... find an old computer and take out the HDD light or the power light)
4. 9v Battery.
5. 9v Battery Connector.
6. Soldering Iron.
7. Multimeter (very helpful if using the headphone jack version)
8. Small box to put it all in.
9. Wire, lots of wire.
10. 1K resistor, to stop LED from burning out
OPTIONAL
0. 3.5mm Jack (take from mp3 player or other)
0. Cheap Headphones
0. Steel wool to test that it all works :)
0. Hot glue gun (also not needed, but helpful)
Step 1: Collect All the Stuff.
This is the general set-up you will be using.
As you can see in the picture once the ARM switch has been flipped the LED will come on showing that there is power going through the circuit.
When the FIRE button / switch is pressed the power is sent through the jack or just wires to steel wool. steel wool is very fine and will glow red hot when a current is passed through it.
Step 2: Having Trouble?
For this step you will connect everything up WITHOUT SOLDER just to check everything works.
If you are having trouble with the headphone jack version, scrap it and just have 2 wires.
Step 3: Put It Together
See the photo below of what mine looks like.
If you ever have troubles putting this together just e-mail me and i will reply ASAP.
As you can see in the photo below I don't have my led connected. ( glue gun fell over and melted it LoL)
Step 4: Test It Out
Here's a link to my youtube account showing the connectors and firing. :)
http://www.youtube.com/watch?v=4XeIvVapA1s
Have fun!!!!!!!!!!!
I like the jack version because it is really easy to use (harder to make though) and easier to transport.
Thanks for viewing
21 Comments
8 years ago on Introduction
nice project to be tested on indian ocassions such as diwali..... nic stuff
9 years ago on Introduction
after looking again does the led light up when the switch is flicked.the parallel circuit design and the fact that the switch offers less resistance when flicked would mean it doesntto my mind.
i like it and will be hacking stuff for parts by tommorow evening
10 years ago on Introduction
good work david ,,,
but you didn't use LED nor resister as you mentioned in the pictures in step 1 ???
good work david
but you don't use Led nor resister(1k) in the last picture ?!!
is it okay if i use alligator clips at the end of the wires??
11 years ago on Introduction
I've done it finally.Works fine too thanks
I am definitely gonna make for my match rockets.
11 years ago on Step 3
the arm switch should have a cover over it. but other than that the thing looks awesome.
Is the steel wool needed or optional to use it?
Reply 11 years ago on Introduction
its needed (its used for ignition), you can buy it almost everywhere
what about the 1k resistor? and wheir can you get it from?
11 years ago on Step 4
why is it my steel wool doesn't burn ? pls answer my question thanks.
12 years ago on Introduction
I don't know a lot of electronics, but adding a capacitor wouldn't make a higher discharge that improves the efficiency of the ignition? If so, what capacitor would fit the best? (If I made mistakes, please correct me ASAP!)
12 years ago on Step 1
Nice design! I'm gonna have a go at making this once I collect all the materials together, I'll upload a photo of it once I'm finished :D
*Purple Guy*
A 680ohm resistor would be fine.
great instructable :D
it would be a perfect combination if u used https://www.instructables.com/id/How-to-Make-Electric-Igniters-from-Christmas-Light/ :D
13 years ago on Introduction
i would try it
Well you can just use a model rocket ignitor and it works fine.
were does fuse go?
