Introduction: Mini Flashlight
This is a double LED flashlight. It is pretty easy to make, and in fun to play with!
2 LEDs
1 3v battery
Tape
Tin foil
Scissors
Step 1: Tape LEDs Onto Tin Foil
Use a thin strip of tape at the top, and thick at the bottom (about 1/2cm apart) to tape down the short leg of the LEDs to the tin foil.
Step 2: Cut and Tape
Then cut off the ends of the foil, (save them for later), and put it on a face up piece of tape perpendicularly. Put two thin pieces of tape at either side of the tin foil tape.
Step 3: Foil
Then cut a piece of tin foil that is the size of the battery, and place it on top. This is so when you fold the face side up tape, it doesn't stick to the battery. Add a thin strip of tape to the battery so you can pull it in and out easily.
Step 4: Finishing Touches
