Introduction: Mini Hover Board Replica
To make this simple mini hover board replica, you'll need:
3\8 inch foam board
templates
red, grean, purpel \ pink and black craft foam
silver paint
masking tape \ pink ducktape
xecto knife
glue
optional:
pink marker (if you are using masking tape )
small plastic pins
Step 1: Printing
Print the templates and cut them out.
Use them to cut the craft foam and foam board. Color the rounded pieces in silver.
Step 2: Cutting
This step is optinal.
You'll need to make a cut near the end of the tail of the hoverboard to make the angel ( like seen in the picture). When you glue the template on, you'll need to cut the top one shorter. After you'll do that, glue the two pieces in your desired angel.
Step 3: Assemble
Color the masking tape pink (or use pink ducktape ) and stick it around the edges. Glue on the tamplates and details ( if you want you can add pins for detail ). If you want you could add a green circle and a pink strap on top.
Step 4: Appendix and Tip
In the picture above you can see the pins. All you need to do is break the pin in half, and push the sharp end through the craft foam into the foam board.
If you don't get a clean cut on the foam board use sand paper.
Back to the Future Contest
6 Comments
7 years ago
What a wonderful idea!!!
7 years ago
Great!!
Makes me feel back in the future :-)
7 years ago
Great!!!
7 years ago
What a beautiful piece of work....
Love it!
7 years ago
Great Back to the Future Prop!
Reply 7 years ago
thank you !!!!
