Introduction: Mini Jettpuff Marshmallows
I will be Teaching you how to make mini Jettpuff marshmallows they look just like the real ones, they dont taste taste the same though
Step 1: Logo
The first thing you need to do is find your own jet puffed marshmallow logo and print it off on the blank piece of paper. If you don’t have access to a computer or a printer you can draw it out.
Step 2: Cutting Out Logo
You will need to cut out the jet puffed marshmallow logo using a pair of scissors.
Step 3: Cutting Q-tips
You will need to cut off the ends of about 20 Q-tips. This will leave you with 40 marshmallows because there are two ends on each Q-tip.
Step 4: Tracing Bag
find the left end of your Ziploc bag. Then place the jet puff logo about 1 cm from the corner. Trace around it leaving 1 cm around it. You will then cut on your line leaving you with a rectangle.
Step 5: Heating Hair Straightener
plug in your hair straightener and place it either on the piece of parchment paper or a cloth. TIP- Put your hair straightener on low to begin with.
Step 6: Folding Pachment Paper
fold your parchment paper in half. Then, place the top open side of your Ziploc bag in the fold.
Step 7: Melting Shut
Slide your hair straightener along the fold of the parchment paper. Leaving the top side melted shut.
Step 8: Inserting Q-tips
Put your jet puffed marshmallow logo facing outward then insert your Q-tip ends and push them down to the bottom so you have enough space to heat the end shut. Repeat step 7 to close.
Step 9:
ENJOY!!! You are now left with a mini bag of jet puffed marshmallows! I hope you enjoyed making this!
