Mini Lego Starship Enterprise
Intro: Mini Lego Starship Enterprise
Happy 45th Star trek!
This will show you how to make a Starship Enterprise model out of Lego's.
Most of the pieces included shouldn't be very hard to come by.
See also:
https://www.instructables.com/id/Mini-Lego-USS-Voyager/
https://www.instructables.com/id/Lego-Deep-Space-9/
https://www.instructables.com/id/Mini-Lego-USS-Titan/
https://www.instructables.com/id/Mini-Lego-USS-Kelvin/
See also:
STEP 1: Pieces
The pieces needed are listed here.
STEP 2: Lower Body
Put the 2x2 and the 2x4 together as shown.
STEP 3: Middel Body
Add a 2x4 on the 2x2.
STEP 4: Rear
Put the 2x3 on the back.
STEP 5: Hinge Plate
Add hinge plate to the 2x3.
STEP 6:
Add the hinges on the 2x3.
STEP 7: Engine Base
Add the black clamps to the center of the hinges.
STEP 8: Start Your Engines
Put the connector pegs to the 1" connectors.
STEP 9:
Add the gray cylinders to the connector pegs.
STEP 10:
Add the small wheels to the other end of the connector pegs.
STEP 11:
Add the other wheels to the gray cylinders.
STEP 12: Finish Engines
Add the transparent blue studs to the wheels.
STEP 13: Attach Engines
Attach engines to the black clamps.
STEP 14:
Add the 2x2 circle plates to the inside of the disks.
STEP 15:
Put the red axle in the axle hole on the 2x2.
STEP 16:
Add the disk on to the body.
STEP 17: Finished!
Put the other 2x2/disk on the red axle.
The ship is done keep reading for the base.
STEP 18: Start Base
Flip the ship upside down.
STEP 19:
Add the hinge brick.
STEP 20:
Add the center stud piece.
STEP 21:
Attach the clear rod to the center piece.
STEP 22: Finish Base
Add the clear bowl to the rod.
STEP 23: Done
You can also adjust the stand on the hinge brick and the clear rod.
Flip back up and you are done! Enjoy!
43 Comments
DeanM10 8 years ago
turdus_migratus 10 years ago
Transforminglegodude 10 years ago
metalsonic 11 years ago
Jetpack5 12 years ago
matstermind 12 years ago
MicioGatta 12 years ago
monsterlego 12 years ago
caelenvasius 12 years ago
omgomgomglol^^ 12 years ago
YOUgNeek 12 years ago
-ML-
onrust 12 years ago
Mark AJA 12 years ago
It's a good module but a lot of the peaces are not 'standard'.
Some of the specialised peaces are:
The top and bottom of the saucer.
The transparent base with a sucker.
The round thin 2x2's.
Etc.
Zalm04 12 years ago
For anyone that is interested in building and does not have the parts to build - here is how to get the parts you need.
If you download Lego's Free Digital Designer (PC and MAC) - you can build the ship within the program and submit it to Lego and they will ship you all the parts you need - you even have the option of getting it in a box that looks all professional with and image of the completed model and step by step instructions as if you are purchasing it from your local toy store - it's an excellent option for a gift. Remember to double or triple your parts if you want to make more then one - and it gets a little cheaper this way.
Here is a link to the program.
http://ldd.lego.com/
You'll spend hours playing with this excellent little piece of software! TIP: You can go on Lego's site and download other users creations and check them out within the program.
bubbaclaw 12 years ago
The ends of the nacelles were red in the show.
