Introduction: Mini Marshmallow Gun
i wasn't sure how well this was gonna shot before making but after i was really surprized how well it shot. Use mini marshmallows to shot out of it. The fresher the marshmallows the better. Also the bigger mini marshmallow the better. The cost of this project was pretty cheap and needed little tools to make. i added tape to make mine look better also added a paracord to it as sling. Yes the marshmallows shot going down then out the front, the caps force the marshmallow out the barrel.
Shoots 10 mphs
shoots up to 50 feet.
COST- cheap
TIME- minimal
TOOLS- minimal
DIFFICULTY- easy
Step 1: Tools and Supplies
jig saw
sharpee marker
ruler
sand pape
2 feet pvc pipe 1/2 inch
2 1/2 t pvc connector
2 L pvc connectors
2 1/2 in pvc end caps
tape or paint
paracord
Step 2: Measure and Cut PVC Pipe
Take your 1/2 inch pvc pipe and start measuring.
1 piece 7 inches long
5 pieces 3 inches long
i used a ruler and marker to make the markings at the measurements
stated above.
then i used a jig saw to cut the pvc you could also use a hand saw.
make sure to cut them straight.
sand down the ends
Step 3: Assemble
once you have your pieces cut and sanded you can start putting it together. Looking at the final product will help you be able to put it together. The long 7 inch peace is the barrel add a T connector to that with the 3 inch pieces in the other sides. Then your other T connector to make the mouth piece part. one of the 45 connectors will be for the mouth piece. the other 45 will be used as part of the handle. i added tape to mine to look cool. camo color this is optional along with adding a paracord sling for carryiing it. ive shot this up to 50 feet pretty cray.
