Introduction: Mini Marshmallow Launcher
You can use your mini marshmallow Launcher to...
shoot mini marshmallows into your mouth, shoot at friends or just have a marshmallow fight!
You will need cardboard tube, tape, small rubber bands,
3 toothpicks and scissors.
Step 1: Making the Shell
Get a cardboard tube and cut it down the middle, then cut off about two inches of the bottom you should have a long strip of cardboard. Fold it in half an cut it in half and cut it, then roll it up and tape it
Step 2: Make Insert
Use the other side of the card board that you cut and cut it in half and make a smaller tube to go inside the bigger one and make sure a mini marshmallow can’t fit in the small one. Poke a hole with the toothpick near the bottom of the small one ( you can use scissors to make a small hole)
Step 3: Slits!!!
On the bigger tube cut a 2 slits small on either side then put the rubber bands in the slits and tape around the top so the rubber bands will not fall out. ( double up the rubber bands to make it stronger
Step 4: Finish
Put the small part in the big part and attach the 2 rubber bands, put the marshmallow in and have a blast
