Introduction: Mini Merry-go Round
The mini Ferris Wheel is a simple project with minimal supplies.
Step 1: Gather Supplies
Lay out you supplies. Thy are 4 small screws, 1 large screw, 2 pieces of cardboard,1 spool of wire, a cardboard painting tray, 2 screw installment holder(the white thing), and 1 very large screws. Tools needed are scissors and screwdriver.
Step 2: Make Your Wheel
Cut 1 of the cardboard pieces into one large wheel, it doesn't have to be perfect.
Step 3: Build the Base
Take the unused piece of cardboard, fold two of the sides in to lift the middle up. Stick one of the screw holders into the middle, use the screw to piece the wheel and then sticking it into the holder.
Step 4: Make and Attach the Chairs
Cut the paint holder into 4 chairs, use a screw to put a small hole in the back of each one. Insert the wire through the hole, cut it, and tie it to the chair. tie the other end around one of the small screws, then insert that into the wheel, repeat 4 times.
Step 5: Make the Handle, Done!
Stick the large screw through the underside of the wheel, screw on the remaining holder, use the handle to turn the merry-go round. You're done!
