Introduction: Mini Monopoly! - Tinker and Play
This is an easy 3D printable project that inspires creativity!
Follow these simple steps to create your very own Mini Monopoly!
Helpful Tip: Make sure to go over the steps before starting the project!
Enjoy! :)
Step 1: Creating the Board
Start off by adding a box/cube to your platform. Then change the height of the box to 6.00, the sides of the box should be around 195.00. Add one more box to your work plane. Then make the box a hole. Press shift and expand the box to 98.00. Align the two boxes so that the hole is in the center of the other box. Don’t group anything yet.
Step 2: Adding the Lines
Grab one more box and stretch it so that the height is 6.00, the length is 6.00 and the width is around 225.00. Copy then paste this 2 times and place them evenly along the platform. Copy a line 1 time and rotate it 90 degrees and repeat the process. Group everything together. Add one more box to your work plane. The box should fit in the holed space, but the height should be slightly under 6.00.
Step 3: Adding the Colors
Grab another box and stretch it so the length is 16.00, the width is 47.00 and the height is 2.00. Add the colors and rotate the rectangles so they fit in the spaces in between the lines of the board. All except for the corners. To make the arrow get the roof shape then rotate it 90 degrees. Make the roof so that the height is 9.00. Add a box shape to your work space and stretch it so that the length is 6.00 the width is 23.00 and the height is 7.00. Put the box shape and roof shape together and make them whatever color you want. Make sure to group them. Put the arrow at the bottom of whatever tile you want the start of your game to be.
Step 4: Creating the Text
Last step, Add the TEXT to your work space. Size the text to whatever size you would like it to be. Copy and paste it 4 times and change 2 of them to, Start and Jail, Move those into 2 of the spaces that have no colors. Copy the TEXT 4 more times. Type, Go To, Jail, Free and Parking. Click on, Go to, press shift then click on Jail align them so that Jail is in the middle below Go to. Do the same for free and parking.
Step 5: Finishing Up
If any of the lines are coming off of the board, then to fix that you can add another box to your work plane. Stretch it so that the height is 20.00 the width is 213.00 and the length is 23.00.
Step 6: Video of the Process
This is just a video of the process I used to get the ending product. https://www.loom.com/share/bf70af9f94184049b13b063e9f091b57
