Introduction: Mini Pallet Organization Board Project
This mini pallet organization board is an artful way to stay organized! All you'll need to create your own is a wood pallet, decorative wrap or paper, clothespins, and basic crafting supplies.
Visit The Studio to see what products we used to make this project.
Step 1: Prep Your Pallet
Start by staining a wood pallet with a dark brown wood stain, or alternatively, use brown acrylic paint. Allow to dry overnight.
Step 2: Prep Your Paper
Carefully cut deco wrap into strips that are slightly smaller than the width of the pallets.
Step 3: Collage Pauge
Using Collage Pauge and a foam brush, generously apply the adhesive leftmost of the pallet's boards. Once the Collage Pauge is on the pallet, slowly and firmly press down your first strip of paper. Repeat this step for each of the pallet's boards, making sure to match up the designs as you go.
Step 4: More Collage Pauge
After each strip of paper has been glued down smoothly, paint a thin layer of Collage Pauge over the entire pallet.
Step 5: Finishing Touches
Paint one side of approx 8 – 10 distressed clothespins with a color of your choice and allow the pins to dry for a few hours. Once dry, attach them to the pallet using a strong liquid adhesive like Diamond Glaze. Then add pieces of a coordinating colored paper or ecology index cards to use for making lists, notes, or writing quotes on the board. You can also add photographs.
