Introduction: Mini Paper Roller (DIY)
Working from home .. and have to note down important dates or notes , or write to-do list.. but nothing in handy ?? This mini paper roller helps you out !!!
This mini paper roller is a easy way to remember important things or note down short notes or even write important messages .
- A flanged plate (1 pc)
- A flexible plate (1 pc)
- An axle (3" - 1 pc)
- Retainers ( 4 pcs)
- A double angle strip (1 pc)
- Strip 5- holes ( 2 pcs)
- Screws 8 mm ( 6 pcs)
- Screws 21 mm (2 pcs)
- Nuts ( 8 pcs)
- Paper roll
- Straw
- Pencil
- Scissors
- Scale
Step 1: Fixing Double Angled Strip Onto the Flanged Plate :
On the flanged plate , first a double angled strip is fixed at the top using the screws and nuts. Making sure the double angled strip is firmly fixed and doesn't move .
Step 2: Fixing the Axle :
Now , take an axle and pass it through the holes at the end of the double angled strip . Secure it with retainers on both the sides .
Step 3: Fixing the Flexible Sheet :
The flexible sheet is fixed on the flanged plate making sure it is tightly fixed and not movable .
Step 4: Fixing the Strip Onto Flanged Plate:
The two strips ( 5 holes) are fixed onto the flanged plate by placing both on top of each , ensuring to leave a small gap between each strip so that the paper can be flipped in .
Step 5: Inserting the Paper Roll :
Now , the paper roll is inserted into the axle . First measure the length of the paper roll required and cut the paper roll . Here I used a plastic straw to support the paper roll. Take the straw and measure the length and cut it . Now insert the paper roll in the straw and insert it into the axle.
Step 6: All Done !!!
The mini paper roller is all ready... Now make important notes , write short messages or make to-do list on this adorable paper roller.
