Introduction: Mini Pocket Bow and Arrow
for this instructable, you will need a Popsicle stick, string, and a BBQ skewer, and maybe hot glue.
Step 1: The Bow
Draw this on your popsicle stick
Step 2: Cuting Out the Bow and Geting It Ready.
I suggest you put the popsicle stick in hot water before cutting it so it does not crack. Then drill holes where the dots are with a pin or something.
Step 3: Giving the Bow Shape.
Using hot water to soften the wood bent the bot in to the shape you want. Then slide the string in the holes and glue them in place. If string does not work use a rubber band that's it! then make and arrow and your done!
