Introduction: Mini Retro TV V2
About: Make it yourself if you cannot buy one ;)
This instructables show how to build a 1:12 Retro TV with a capsule toys.
Step 1: Simplified Design
I have made 2 Retro TV before:
  1. https://www.instructables.com/Mini-Retro-TV/
  2. https://www.instructables.com/Mini-Retro-SPYFAMILY-TV/
This time is a simplified version. It only has 4 components, a capsule toy, a dev board, an audio module and a speaker.
So it's perfect for beginners, you still need soldering skills through.
Step 2: Software Preparation
Arduino IDE
Download and install Arduino IDE latest version if not yet:
https://www.arduino.cc/en/software
Arduino-ESP32
Follow installation step to add Arduino-ESP32 support if not yet:
https://docs.espressif.com/projects/arduino-esp32/en/latest/installing.html
Arduino_GFX Library
Open Arduino IDE Library Manager by selecting "Tools" menu -> "Manager Libraries...". Search "GFX for various displays" and press "install" button.
You may refer my previous instructables for more information about Arduino_GFX.
Dev Device Pins
Open Arduino IDE Library Manager by selecting "Tools" menu -> "Manager Libraries...". Search "Dev Device Pins" and press "install" button.
JPEGDEC
Open Arduino IDE Library Manager by selecting "Tools" menu -> "Manager Libraries...". Search "JPEGDEC" and press "install" button.
arduino-libhelix
Download and import the arduino-libhelix library to Arduino IDE:
https://github.com/pschatzmann/arduino-libhelix.git
Note:
You may refer to Arduino Documentation for the details on how to install/import library to Arduino IDE.
Step 3: Video Preparation
Select your favor videos and convert it to AVI files.
Here are the sample convert command:
ffmpeg -y -i input.mp4 -ab 64k -ac 2 -ar 44100 -af loudnorm -c:a mp3 -pix_fmt yuvj420p -c:v mjpeg -q:v 11 -vf "fps=10,scale=320:-1:flags=lanczos,crop=320:172:0:(in_h-172)/2" output.avi
Then create a folder called "avi" in MicroSD card, copy all the converted AVI files into the folder.
Ref.:
https://ffmpeg.org/ffmpeg.html
Step 4: Upload Program
This project use aviPlayer developed in my previous project for playing video.
  1. Download the source code at GitHub: https://github.com/moononournation/aviPlayer.git
  2. Open "AviPlayer_callback/AviPlayer_callback.ino" in Arduino IDE
  3. At around line 30, ensure below line is uncommented and other Dev Device header file all are commented:
#include "PINS_ESP32-C6-LCD-1_47_I2S.h"
Then compile and upload the program to Waveshare ESP32-C6-LCD-1.47.
Note:
You can see the video playing after program uploaded. Prepare the software part ready first so that you can test the audio module soldering work instantly at below step.
Step 5: Full Making Steps
Please follow the video for the full making steps. Here are the connection summary:
esp32-c6-lcd-1.47 MAX98357A Speaker
5V -> Vin
GND -> GND
GP1 -> DIN
GP2 -> BCLK
GP3 -> LRC
SPK + -> red wire
SPK - -> black wire
Note:
  1. This project use a short pin header to connect the dev board and audio module for easier plug and remove. If you do not have short pin header in hand, direct soldering the connection with wire is ok.
  2. The USB power cable can use any old USB power cable bundle with the gadgets that only for charging only. The charging only USB cable is better than normal USB data cable because it only have 2 wires for power supply so the cable is thinner in most case.
  3. The TV screen size is a little bit wider than the 1.47 LCD, so I use a PET plastics plate and some black double adhesive tape to mask the gap. You can reclaim the PET plastics plate from any product package.
Step 6: Enjoy!
Now you have a playable Retro TV for your 1:12 doll house!!
