Introduction: Mini Roses
this crafting project is mini roses. it is a perfect and easy way to add any color to room or as a gift.
supplies you will need
- masking tape
- scissors
- ruler
- any pen or pencil
- green paper
- colored paper of your choice
Step 1: Measuring and Cutting
on your pink paper measure 5 cm by 5cm and do the same with your green paper. once you have that cut the squares out of the paper.
Step 2: Making the Leaves
Draw five lines on the right side of the green square, and make the spaces a pinky width apart. Once you have done that cut the lines.
Now on each of the little squares fold both corners in to make a triangle.
Step 3: Creating the Roses
Get out your red paper and fold it on the right side and the top of the square.
once you have that starting from the ride side begin to roll the paper
Step 4: Putting the Paper Together
now that you have your red rolled paper and the green with the leaves, wrap the green around the red.
Since it is all rolled up now you have to make sure it doesn't unravel, use about 2 cm of tape to secure you're flower at the bottom
Step 5: Making Your Vase
on a paper towel or toilet paper roll, measure 4 cm, and cut it there.
now cute 1 cm off the bottom
using the roll trace a circle on your leftover cardboard and cut it out.
Step 6: Gluing the Vase Together
grab your 4 cm roll and cut a slit in it to size it down a little, then get your 1 cm piece cut that down the middle, and hot glue it around your sized down 4 cm roll.
Now with your circle piece that you cut out earlier, glue that to the bottom of the roll
Step 7: The Finished Product
finally, for your finished product, you can make however many flowers you want, I made nine because I think they fit the best with the size of the vase.
You can also add any finishing touches you want to your vase like paint, glitter, and marker. I chose to create a heart out of leftover cardboard and glued it on the front
