Introduction: Mini-Sandwich Maker
Here is a great project the year end, or for entertaining friends or family.
Mini Sandwich maker " Twist" is now available .
It is a great gift idea .
I will make several series that I will offer to my sister, my parents, my brother, my friends and my college work. It is easy and fast to print, I am sure it will please. The most interesting is that it is a great gift that does not cost expensive.
We always like to have innovative things and the New Year's Day is soon, it will be very useful. Children can also join in creating fun mini sandwitch.
I think my gift will be used a lot.
In French gastronomy the presentation and the decoration are as important as the quality of the dishes
It will let you make many mini sandwich.
The files are available for download, but you can also use OpensScad (http://www.openscad.org/). You will then be able to change the size (height, width, depth) for it to be not all the same.
Choose the type : Cylinder, Hex, Square, Octagonal, Oval, Rectangle, Rectangle with Bevel, Heart.
Choose the axis type you prefer: Hex, Square, Cylinder.
You can also chose the cap: Cube or Sphere. (Personally I find the prettiest sphere but it is a matter of taste)
Your guests always appreciate these little appetizer.
If you are having any difficulties, need advices or you want me to make changes, I remain at your disposal.
If you want to learn OpenSCAD you can follow my video tutorials :
Step 1: How to Print and How to Use
You either print the attached files and you need to pay attention to the axis you want to use. Either you use OpenScad, made your settings and generate all the parts with the same setting.
For the base I recommend the use of transparent PLA to check where you are in your cut. The remaining parts can be printed in your favorite color.
For installation I suggest you stick the Axis and the Cap. I do not advice to stick the axis and the pusher because you will have problems for cleaning after use.
To use Mini-sandwich:
- Make a simple sandwich with sliced bread.
- Then add of butter or other on top of the sandwich so that superimpose party can paste between them.
- Use it as a cookie cutter. Layer by layer.
- Once the desired number of layer sting a small toothpick and push the piston
- Your mini-sandwich is done.
You can also make fun desserts:
- Take a piece of cake and cut it with the mini sandwich maker
- Add ice cream
- Put back at the end of cake
You will have desserts that will delight your guests
Step 2: Mini Sandwich Maker Twist Edition
In this other version, this is Mini-Sandwich Twist edition
I had to make many changes because I wanted the pusher to be able to turn in the base.
Choose the type: hex, square, octagonal, oval, rectangle, rectangle with bevel, heart.
If you have any difficulties, need advices or you want to make changes, I remain at your disposal.
Step 3: Files : Mini-Sandwich Maker
Here are the files for "Mini Sandwich Maker"
AxisCylinder.stl
AxisHex.stl
AxisSquare.stl
Base_Cylinder-AxisCylinder.stl
Base_RectangleSquareBevel-AxisSquare.stl
Base_Rectangle-AxisCylinder.stl
Base_RectangleSquareBevel-AxisHex.stl
Base_Rectangle_SquareBevel-AxisCylinder.stl
Base_Oval-AxisCylinder.stl
Base_Cylinder-AxisHex.stl
Base_Octogonal-AxisSquare.stl
Base_Heart-AxisSquare.stl
Base_Cylinder-AxisSquare.stl
Base_Hex-AxisCylinder.stl
Base_Hex-AxisHex.stl
Base_Heart-AxisCylinder.stl
Base_Octogonal-AxisCylinder.stl
Base_Heart-AxisHex.stl
Base_Hex-AxisSquare.stl
Base_Rectangle-AxisSquare.stl
Base_Octogonal-AxisHex.stl
Base_Oval-AxisHex.stl
Base_Oval-AxisSquare.stl
Cap-Sphere-AxisHex.stl
CAP_Cube-AxisSquare.stl
Cap_Sphere-AxisCylinder.stl
Pusher_Octogonal-AxisHex.stl
Pusher_Heart-AxisSquare.stl
Pusher_Hex-AxisHex.stl
Base_Square-AxisSquare.stl
Full_AxisCylinder_1OF2.stl
Base_Square-AxisHex.stl
Pusher_Square-AxisSquare.stl
Pusher_Oval-AxisHex.stl
Pusher_Rectangle-AxisSquare.stl
Pusher_Oval-AxisSquare.stl
Base_Rectangle-AxisHex.stl
Base_Square-AxisCylinder.stl
Pusher_Hex-AxisCylinder.stl
Pusher_Heart-AxisHex.stl
Pusher_Cylinder-AxisSquare.stl
Pusher_Cylinder-AxisCylinder.stl
CAP_Cube-AxisCylinder.stl
CAP_Cube-AxisHex.stl
Cap-Sphere-AxisSquare.stl
Pusher_Hex-AxisSquare.stl
Pusher_Octogonal-AxisCylinder.stl
Pusher_Octogonal-AxisSquare.stl
Pusher_Oval-AxisCylinder.stl
Pusher_RectangleSquareBevel-AxisSquare.stl
Pusher_Rectangle-AxisCylinder.stl
Pusher_Rectangle-AxisHex.stl
Pusher_RectangleSquareBevel-AxisCylinder.stl
Pusher_RectangleSquareBevel-AxisHex.stl
Pusher_Square-AxisCylinder.stl
Pusher_Heart-AxisCylinder.stl
Pusher_Cylinder-AxisHex.stl
Pusher_Square-AxisHex.stl
Mini-Sandwich_Maker.zip
Mini-Sandwich_Maker_V0.7-Rudy_Ruffel.scad
Full_AxisCylinder_2OF2.stl
Step 4: Files : Mini Sandwich Maker Twist Edition
Here are the files for "Mini Sandwich Maker Twist Edition"
Heart-AxisPusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Heart-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Heart-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Heart-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Hex-AxisPusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Hex-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Hex-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Hex-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Mini-Sandwich_Maker_Twist-EditionV1-Rudy_Ruffel.scad
Octogonal-Axis-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Octogonal-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Octogonal-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Octogonal-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Oval-Axis-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Oval-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Oval-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Oval-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Rectangle-Axis-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Rectangle-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
RectangleBevel-Axis-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
RectangleBevel-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
RectangleBevel-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
RectangleBevel-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Rectangle-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Rectangle-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Square-AxisPusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Square-Base-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Square-Cap-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Square-Pusher-Mini-Sandwich-Maker-Twist-Rudy-Ruffel.stl
Mini_Sandwich_Maker_Twist_Edition.zip
