Introduction: Mini Stone Bowl
A stone bowl carved from orange alabaster.
Step 1: The Tools
Tools for hand held carving:
1. Face mask
2. Small hammer
3. Leather gloves
4. Small piece of Alabaster Stone (orange alabaster in picture)
5. Needle pick
6. Coarse and fine rasps & files (small to medium in size)
7. Mini (watch) screw drivers (used as chisels)
Step 2: Start Chipping
Start by drawing a circle with a marker on a flat side of the stone, of which will be the opening of the bowl. Then, with your face mask and gloves on, grab the small hammer in one hand, and a sturdy needle pick in the other hand. Begin by gently striking with the pick and hammer at the interior of the drawn circle (be aware that the bowl needs a rim as well- leave about 5mm to 7mm space from the edge of the stone to form a rim). Start chipping away the stone to slowly reveal the cavity of the bowl (see pics). Feather blow by blow, chip by chip, flake away the alabaster to carve out the bowl from the stone. Be careful not to strike so hard that the stone cracks or worse, breaks. Keep coarsely chipping away the bowl of the stone. Do this until the desired depth is reached, just before the bottom of the stone is reached. See pictures for example of how this looks..when done move on to the next step.
Step 3: Forming the Body of the Bowl
To do this, grab a coarse/spiked file or rasp. Start by filing the stone vigorously until all sides are to the desired curvature. Work the sides of the stone. Be aware the Alabaster is a soft stone, so not to much pressure on the stone, just enough to warm it and shape it. See pics for example. After this step is done, you should have a coarsely carved mini stone bowl. Move on to the next step.
Step 4: Fine Chisel and Filing
After this step, there is just one more step to follow...
Step 5: Oil to the Stone
Step 6: The Finished Bowl
Looking good!
