Introduction: Mini Wall Decoration Paper Flower Craft
About: I love to cook and diy craft
The beauty of every room increases by increasing the beauty of the walls of that room. If the walls of a room are beautified then the room itself looks very beautiful. So, to make the house look beautiful, the walls must be decorated.
So today I have brought 'Mini Wall Decoration' which will make your house more beautiful. This decoration requires very little space. Most of us think that decorating a house takes a lot of space, but it is not so.
It looks small but its meaning is big. There is a empty cradle, trees and plants full of flowers and grass. Which indicates a phenomenon of nature involving us. This event may be present for some and past for others. For those who are still experiencing the phenomenon, they are very lucky because nature is being lost in the crowd of high-rise buildings surrounded by walls. Children used to swing in tree swings, fresh air around, flowers and leaves of trees overhead which are now disappearing. And I made it with that in mind. When you look at it you might remember your childhood.
I don't know what you will think about it but if you read my description you might understand.
You can also call this decoration as reminisce
Tools:
  • Pencil
  • Erassor
  • Pencil Compass
  • Scale
  • Scissor
  • Casket
  • White Glue
CARDBOARD
  • H-11cm/W-6cm cardboard for making Background
  • H-11cm/W-1cm cardboard for making Frame's Hight
  • H-4cm/W-1cm cardboard for making Frame's Width
PAPER
  • Grass green colour paper
  • Red colour paper
  • White paper( if you use A4 size paper it will be better becuse A4 size paper is strong than a normal paper)
COLOUR
  • Black poster colour
  • Brown poster colour
  • Brush
Step 1: Backgrond and Frame Procesing
First we need to create the background. So measure and cut a cardboard (width 6 cm and length 11 cm). Then wrap the cardboard in white paper.
After that, cut cardboard for the Frame and The measurements are H-11cm/W-1cm cardboard for making Frame's Hight, H-4cm/W-1cm cardboard for making Frame's Width and have to be attached with glue in background and cover them in white paper.
Step 2: Flower Cutting
Now make the flower according to the steps shown in the picture. For this, 7 circles of 1 cm diameter should be cut from the red colour paper.
Then the circle should be folded 3 times and cut out with a pencil mark as per the picture. Now open the circle and you will see a beautiful flower.
Step 3: Leaves and Grass Making
Now we have to make the leaves and grass, for this we have to cut the leaves from the green paper (here you can cut the leaves according to the design you like)
To make grass, cut 4 cm paper and cut into small pieces as like the picture
Step 4: Art and Cut
Draw a tree with pencil on white paper and use eraser if wrong and cut it with scissors carefully
Step 5: Colour and Tree Set Up
This time we have to mix the colour in the casket for colouring the frame boarder, cradle in black colour and tree in black + brown colour .
And attach the tree and cradle on background with glue.
Step 6: Attachment
Attach the grass with glue on frame.
Then, spread the leaves and flowers with glue on background.
Step 7: Final Look
Let's decor your wall with reminisce. when you will see this in your wall you will remember your old days.
