Introduction: Mini Warhamer DIY
In this DIY I will show you how to make a mini hammer with basic materials. Please no hate this is my first DIY so it may be a little bad.
Step 1: Tools and Materials
To make this you will need:
- Metallic Paint
- Sand Paper
- Glue
- String or Leather Strips
- A Knife
- A Cork
Step 2: Cutting the Cork
Using the knife cut the part that has the wine on it (If the cork is new skip this step). Draw a circle on both sides of the cork cut them out so you get a slight decline. Draw 2 thick lines on the cork (Here is where you will put the sting or leather strip) cut then out enough so the string or strip will fit but not too much because ti can break.
Step 3: Finishing the Top Part
Paint the cork (I used spray paint but any kind of paint is okay), be sure to cover it all. Then Put the strip or string in the hole you made for it, finally make a hole at the bottom of the cork (You will put the handle here)
Step 4: the Handle
Cut a stick that is about 2 inches long. Using paper make a cone like shape at the bottom of the stick then paint it or cover it with aluminum. Then get the leather strip or sting and wrap it around the stick, paint the leftover part of the stick black and put an aluminum tip on the middle part.
Step 5: Putting It All Together
Just paste the handle onto the top part where you made the hole (Step 2). Enjoy
