Introduction: Mini Waterfall Scene
I decided to make a mini waterfall scene. I got this idea from going on a nature walk and seeing very pretty scenes. This scene takes place in the late fall, early winter.
Step 1: Cut and Glue Cardboard
the first thing that you need to do is to cut out 2 pieces of cardboard and glue them together.
Step 2: Cut and Glue Foam
Now you need to cut 2 pieces of foam that can go on top of each other and glue them to each other and then to the piece of cardboard.
Step 3: Paint!
After that, you need to get some sort of brownish color paint and cover the foam in it.
Step 4: Rocks and Tree
Once that is done you, have to get a small tree branch, make it look like a tree, and poke it into some foam so that it will stand up. You will also get the small rocks and pebbles that you collected and hot glue them onto your waterfall.
Step 5: Plastic Wrap and Leaves
last but most definitely not least, you are going to get some plastic wrap and cut and wrinkle it so that it looks like water, then you are going to hot glue it onto your little mountain. then you will collect the leaves and weeds that you got and you will glue them all over the bottom of the cardboard so that it looks like the ground.
Step 6: CELEBRATE!!!
Now, you're going to celebrate your wonderful creation! Great work!
