Introduction: Mini Yarn Unicorn (or Horse)
This Instructable will cover how to make a cute mini yarn horses.
- Yarn
- Embroidery floss
- Needle
- Felt
- Thread
- Googly eyes
- Pipe cleaners (at least 3)
- Cardstock
- Glue
Optional:
Rubber bands
Step 1: Form the Head and Front Legs
- Wrap some light weight or thing yarn around a piece of cardstock (3 x 4.5 inches) about 25 times.
- Bend and cut a pipe cleaner sized fore the yarn loops (see image above)
- Save the little extra piece of pipe cleaner (we can use it to make the horn)
Step 2: Tie the Head
- Remove the yarn loops from the cardstock
- Twist a little less than half of the pipe cleaner around itself
- Take the twisted end and place it inside and between one of the ends of the yarn loops (see third image above)
Step 3: Form the Head
NOTE: Halfway through this, I realized my yard broke off easily so I switched to embroidery floss for the knots (you will see this with the legs)
- Tie a knot close to the end of the loops with a little embroidery floss
- Take care to also hold the pipe cleaner with the knot
- Tie a second knot to form the rest of the head
- Cut the opposite end of the loops (the ones that are far from the knots
- This will form the legs later
- Bend the pipe cleaner and yarn just under the second knot to shape the neck
Step 4: Wrap the Body
Set the head and front of the body aside for now
- Wrap about 25 loops of the same yard around the same piece of cardstock
- Slide a piece of yarn (or embroidery floss) through the loops and tie a knot
- This will be the horses' chest
Step 5: Form the Body
- Cut the loops at the opposite end of the knot
- Separate the strands into to pieces
- Cut a pipe cleaner the size of the strands on yarn and bend in half (see third image)
- Place the middle of the pipe cleaner agains the the middle of the yarn strands
Step 6: Assemble the Body Parts
- Take the stands we just formed and wrap them around the front of the body under the head
- Tie a knot around the body as close to the front of the body as possible (see second image above)
- Tie a second knot away from head, this will form the horses hindquarters
The yarn strands were getting in the way so I used a rubber band to hold them together and out of the way
Step 7: Form the Legs
- Separate them back legs
- Make sure each bundle has a pipe cleaner end wrapped up in yard
- Tie a knot about half way down
- Repeat on the front legs
- Tie a second knot on each of the legs. This should be lower than the first one
- Trip the excess yarn
Step 8: Form the Mane
- Wrap a few loops of embroidery floss on the short side of the cardstock
- Pass a piece of floss between the loops and cardstock and tie together
- Remove loops from the cardstock
- Cut the loops
- Trim the excess string from the knot holding everything together
Step 9: Sew on Mane
- Take apiece of floss about 6 inches in length and separate it into its 6 threads
- Thread a needle with one of the strands
- Place the mane on the horse's head
- Sew in place
Step 10: Prep Tail
- Take embroidery floss and loop it around two fingers a few times
- Remove the loops from your fingers and secure the loops together with a piece of the separated floss strands from earlier
- Cut the loops at the opposite side of the tied segment
Step 11: Sew on Tail
- Trim the excess floss holding the tail together
- Thread a needle with a single strand of the separated floss
- Place the tail on the horse
- Sew in place
Step 12: Prep Ears
- Cut two little tall triangles out of felt for ears
Step 13: Glue Eyes and Ears in Place
- Place two tiny drops of glue on the horse where the eyes should be
- Gently place the eyes in the glue
- Add a little glue to the bottom of the ears and glue in place
That's it, make as many little horses and you'd like. If you want to make a unicorn, follow the next step.
Step 14: Prep Horn
- Take 2 pipe cleaners of different colors and twist them together.
- Use two new ones or you can use the little left over piece from earlier and a new one
- Cut to size, leaving a little extra to insert into the head
- Insert the horn into the head
- If you want it to be more permanent, twist the base of the horn together and glue in place
Since this is the first time I have made these, I would love to see your version and see how you improve on it.
