Introduction: Mini-bag in Which You Can ACTUALLY Find Stuff!
I bet we have all had times when our handbags simply swallow all the small objects we put inside. Luckily that is not the case with this cute mini-bag, using Circuit Playground Express to light up the inside with the click of a button. Not only is it awfully practical but also a fashion statement to spice up simple outfits.
  • Circuit Playground Express
  • 1/2 meter of fabric (extra if you have large-print fabric that you want to pattern-match)
  • Sewing machine
  • Needle
  • Thread
  • Zipper
  • Metal ring
Step 1: Draft Pattern
Either draft your own pattern or follow the instructions below.
Strap: 93cm * 8cm
Front*2: 24cm * 14cm (connect in a curve)
Bottom: 39cm * 8.5cm (connect with 2 mirroring curves)
Strap connecter*2: 8cm * 8cm
Step 2: Cut Out Pieces
Cut out the pattern you just drafted.
Step 3: Cut Fabric
Bobby-pin the pattern to your fabric and cut it out with fabric scissors. In the case of a printed fabric take into consideration what pattern you would like at the front of your bag.
Step 4: Sew Stiffener to Bottom
Sew a stiffening foam slightly smaller than the bottom to the fabric.
Step 5: Sew Front and Back to Bottom
Depending on if your fabric frays or not you might want to French seam the edges to provide extra support.
Step 6: Sew the Strap
Sew the right sides of the strap together and then turn it inside out.
Step 7: Sew the Strap Connector
Follow the same instructions as for the strap: sew the right sides of the strap together and then turn it inside out.
Step 8: Sew Strap Connector Onto Bag
When sewing the strap connector to the sides of the bag, make sure to loop it through the metal loop.
Step 9: Sew on the Strap
Sew either side of the strap onto a hardware loop.
Step 10: Hand-stich Zipper On
Hand-stich the zipper onto the bag for a neat finish.
Step 11: Program Circuit Playground Express
Code your circuit playground express using MakeCode. I personally went for very simple code that will turn the lights on and off, however you can make it fancier if you want. Then afterwards upload your code to the CPX.
Step 12: Sew the CPX Into the Bag
Hand sew the CPX and battery into the bag.
Step 13: Enjoy!!!
I hope you loved making this bag just as much as I did, and will never loose small items in our bag again!
