Introduction: Mini Knex Gun
This instructable is about my awesome mini knex gun. it was the first knex gun i've ever made but since i made it i have improved it a little. hope you enjoy it.
Step 1: What You Need
You will need:
-3 orange connectors (mine are brown because i was out of orange)
-2 Y clips
-4 light gray double connectors in the shape of a triangle
-3 single gray connectors
-3 blue rods
-1 white rod
-little green pieces for ammo
-and as many elastics as you would like (i use 3)
-2 Y clips
-3 blue rods
-1 white rod
Step 2: The Main Body and Trigger
build what you see below. i know most people don't like block triggers but this guns' power and shot length makes up for the trigger. the first pic is just the first step then you add the blue rod you don't make 2 body's.
Step 3: Handle
build as you see below, just 2 different views. the black things on the brown connectors are the Y clips
Step 4: Ram Rod
Step 5: Loading and Firing
push the ammo in the front end, pull the rod back, and push in the trigger in to fire
