Introduction: Mini Tophat Fascinator
I was asked to officiate/MC at a circus themed wedding, so I thought it would be fun to wear a tophat, kind of like the ringmaster. After trying on a few tophats in a store, I decided I was better off with a tophat fascinator. I have a funny face and large head, which results in me looking like a freak of nature in hats most of the time, trust me. Anyway, etsy searches turned up these ones, that I fell in love with.
http://www.etsy.com/listing/63523968/red-rum-a-symmetrical-mini-top-hat?ref=v1_other_1
Love it! But not so much the price though, $96 ? Ouch. So of course I decided to make my own, and thought I would share the pattern.
NOTE: this pattern/tut is for PERSONAL USE ONLY. Please do not sell tophats you make from this pattern. I took my idea from someone who is selling it, we should at least show her some respect by not competing with her.
If you make one of these, please please send me a picture! I would love to see what people come up with.
More tutorials and other crap I make & do at hungrypanda.net
Step 1: Stuff You Need
* Pattern
* Thin cardboard. I used a cereal box, but a tissue or shoe box would work equally well.
* Fabric to cover your hat. I like damask, but you can use any thick wovens, upholstery fabric would work well here. If the fabric is too thin, your glue will show through.
* Hot glue/glue gun
* Glue for gluing your fabric to the cardboard. I used modge podge because I was too lazy to dig in the garage for my fabric glue, but that would work well also.
* Trim
* Elastic, preferably in a color that blends with your hair. I used 1/4 inch, although I think next time I might go thinner since my ears hurt after wearing it for a while.
* Feathers/other decorations.
* Hot glue/glue gun
* Trim
Step 2:
Print out pattern. I scanned it in on regular letter sized paper, so if you print it out that size, it should work. I need to add a size marker to the patterns next time. Notice that pattern pieces are labeled A, B and C.
Transfer the pattern markings to cardboard. Piece A & C can go any direction. Piece B should be placed with the writing “this side top” on top. Meaning, don’t flip the pattern piece over so the writing on the pattern is face down when you trace it. You should trace 1 copy of each piece.
Step 3:
Cut out your cardboard pieces. Score the lines on the cardboard where indicated, fold up the little tabs on piece A and C, and also the solid tab on piece B. The little tabs gives the pieces a place to attach to each other.
Mold your pieces. I found it was helpful to premold the cardboard a little before attaching the fabric to it. It caused less wrinkles in the fabric. I wet each piece quickly under a running facet and just molded it a bit with my hand into the desired final shape. I taped things temporarily with painters tape and waited until the pieces dried completely. This is important, otherwise as you try to glue all the pieces together, they can disintegrate.
Step 4:
While the cardboard pieces are drying, you can cut out the fabric. You will need 1 of piece A, without the tabs. 1 of piece B without the solid tab. You will need 2 of piece C, 1 with the center circle and tabs removed, and 1 with the center circle not removed. Put aside the fabric with center circle not removed for now.
Glue the fabric to cardboard pieces. Be careful to not get the glue on the outside of your fabric. Wait till everything dries.
Step 5:
Hot glue the solid tab of piece B to itself.
Carefully mold piece A into piece B, hot glueing the tabs to the inside (non-fabric side) of piece B. This is by far the hardest step, and where it really helps if you molded your pieces in step 4. The fit does not have to be perfect, as we will cover up most of the mistakes with trim later.
Step 6:
Attach piece C to the bottom of piece B, hot glueing the tabs to the inside of piece B. See, it’s starting to look like a hat!
Step 7:
Now we are going to work on the part that attaches to your head. I have seen people just attach fascinators with just combs and pins, but having slippery Asian hair I knew that was not going to work for me, so I decided to go with elastic. Cut a piece of elastic that is long enough to go around your face, starting at where you want the fascinator to rest, and then tucking behind one ear, your chin, the other ear and back up on your head again. Add a little extra for the knots we will have make.
Take the piece of fabric you put aside in step 5, eyeball where the center circle is roughly. Make two small incisions inside the center circle for the elastic to go through.
Feed each end of the elastic through the incisions.
Cut out two small pieces of cardboard, and feed the ends of your elastic through that and knot it so it won’t slip out. I added in these pieces of cardboard because the point where the elastic attaches to the hat will suffer a lot stress since it’s stretched around the head. So larger surface area is needed for the glue to get a firm grip, otherwise you would just be gluing the knotted ends of the elastic to the hat.
Step 8:
Matching the poistion of the fabric to the position of the hat, (basically make sure the pointed end of the fabric is matched with the pointed end of the hat) hot glue the elastic and cardboard inside piece B.
Once the hot glue has dried, try out the whole contraption on your head. Make sure the elastic is secure enough as you really would rather fix it now than once you have done all the other steps.
Step 9:
With the fabric glue or modge podge, glue the fabric onto the bottom of the hat.
Step 10:
Now we will hide the icki areas with trim. If you selected the same type of trim as I have, you will see it’s quite easy to match the midpoint of the trim to the seams of the hat, therefore ensuring equal coverage on both sides of seam. I started by hotgluing the trim from the back of the hat, around and down. Follow the magenta arrow! At the end, tuck the loose ends of the trim under itself. Do the same for the brim of the hat.
Step 11:
Yay, time for decorating. I used goose biot sword feathers, rooster tail feathers and a little robot I had laying around. Remember, in general things look better in odd numbers.
