Miniature Floating House in a Bottle
Intro: Miniature Floating House in a Bottle
Hello All,
In this instructable, I will share how to make this miniature floating house in a bottle. We will be recycling, most of the items commonly found at home...
STEP 1: What Do We Need?
- Cardboard ( Amazon delivery box)
- One popsicle stick
- Old Chutney bottle or glass jar
- PVA glue or fevicol
- Acrylic colors and paint brushes
- Cutter and scissors
- Coco peat - small amounts
- Wire
- LED
STEP 2: Base
- The base is like a domes shaped piece of land with flat top surface
- To create this, cut few circles of cardboard as shown
- Stick each cardboard in descending order
- Make sure that the base size is much smaller then the neck of the bottle
- The base will be stuck at it's back to give the floating illusion
- So we have added additional flat cardboard as shown
- Let this dry for 30 minutes
- Now apply PVA glue or fevicol on the curves side of the base and stick coco peat to it
- You could use colored sand or dirty as well
- This needs to dry for 1 hr and then apply 2nd layer of coco peat
STEP 3: House
- I have used a large popsicle stick to make the house, It is about 0.5 " in size
- Cut house walls from popsicle sticks
- Use paper tape to hold the walls in position and stick the house walls using glue
- After drying, add cardboard (corrugated box) roof
- Using Arcylic paint, draw windows, doors and paint the walls and roof
STEP 4: Tree
- Take few pieces of wire (3")
- twist and turn to make tree like figure
- Remember to add wire loops at the end
- Paint the tree brown using acrylic paint
STEP 5: Leaves
- To prepare green grass and leaves, I used Coco peat and colored it using green paint
- I recommend to use lighter shade of green as, the coco peat will darken after it dries
- After coco peat is dried, I filtered smaller particles an used them as leaves or grass
- Apply glue on the tree and dig it in colored coco peat
- Let it rest for 10 minutes and repeat few times to get thick tree look
STEP 6: Detailing
- Add moss or creeper on the roof and walls using glue and sprinkling green coco peat on it
- Once this is dried, using a tooth pick clean excess coco peat to make prominent lines etc
- Stick the house on the base
- Apply glue around the house and sprinkle green coco peat as symbol of grass
- Stick the tree on the side of the house
- Let everything dry
STEP 7: Assembling
- Gentling push the house and land inside the bottle
- Glue the land on the bottle, remember we have to stick it at the back, to give the floating effect
- Add a led and cover the neck using cardboard cap
Hope you liked this project, Please share your comments or suggestions
3 Comments
FunFriday 3 years ago
NirL 3 years ago
Amit_Jain 3 years ago
