Introduction: Minimalist Root and Black Lava Stone Table Lamp पेड़ की जड़ और लावा पत्थर से लैंप
Found this S shaped root on my morning walk route and struck an idea to create a table lamp with it. For its base I picked a black lava stone which is very common around Kaliyasot Dam, Bhopal
Tools required:
- Clear spray varnish
- Brush for cleaning the root and stone
- Drill to make a hole in stone
- Rice LED light
- A Bulb which has filament removed
Step 1: Prepare Black Lava Stone and the Root
Wash and clean the stone and root and dry them. Apply a clear coat of varnish and repeat this process three four times.
Step 2: Fix the Root on the Black Lava Stone Base
Decide which way it will look elegant. Drill a hole using stone or concrete bit and fix a wooden dowel (I used an Ice Cream stick) in the stone upto one inch depth. Keep the dowel one inch out side the stone and cut rest of it. Make a hole in the root at appropriate location and fix it on stone.
Step 3: Hollow a Bulb and Rice LED Light
Hollow a bulb by removing the filament. Tie a fine copper wire to hand it from the root. Drop a rice LED light and hide its battery behind the stone or the root. The Minimalist Lamp is ready!
