Introduction: Missile Launcher
When the times comes you better be ready! Ready to blow that stuff out of the sky.
Step 1: Recycle
The best part of any project is finally finding a use for the junk you stored around your house for years. BAM!!! It finally clicks. You know what you are going to use those old water conditioner cylinders for. Let's make a BOMB!
Step 2: You Are Never Going to Get Anywhere Unless You Learn to Cut Some Corners. HaHahaha
Step 3: Fins
A 2x4 up the center of the tube, the hole had to be squared out a bit to fit the 2x4 and then screw in the other end keeps everything together. slap on your fins and then add some paint. Done!
Step 4: Get Your Angle Set. Aim High!!
what good is a BOMB unless you have something to launch it from. I used the cargo basket from the car and built a wooden frame from plywood and 2x4's. cut out a contour shape of the cylinder so it wouldn't roll off and explode on the ground.
Step 5: There It Is.
Step 6: Plus 2
and if you have a 500lb Bomb you have to have some Stinger Missiles to back it up.
Step 7: Test Fit
ok let's see how it looks up there. Lights have to have light too. the nose cones for the missles are plastic cemetery vases you can put flowers in. there were attached by drilling a hole in the side a filled with expandable spray foam. some epoxy was also used later for a tighter bond.
Step 8: Labels
Step 9: Show It Off
Step 10: Don't Get Caught !!!!!
Step 11: Have Fun, Be Creative. Hope You Liked My Props!
This NOT a real Bomb!!!
