Introduction: Mississippi Mud Pie
This recipe will make a rich and luscious Mississippi Mud Pie - An Oreo cookie base layer, topped with brownie, and finished off with chocolate pudding and caramel decorations. Fresh fruit, such as strawberries, can be used as a garnish to finish off the dish. Enjoy!
Base:
- 20 Oreos
- 100g Salted Butter
- Cooking Spray or Extra Butter (for greasing)
Brownie Layer:
- 225g ~75% Cocoa Baking Chocolate
- 200g Unsalted Butter
- 100g Caster Sugar
- 300g Brown Sugar
- 4 Eggs
- 125g Flour
- 1-2 Teaspoon(s) Vanilla Extract
- ½ Teaspoon Salt
Chocolate Pudding Layer
- 500ml Milk
- 150g Caster Sugar
- 50g Cocoa Powder
- 50g Flour
- 25g Unsalted Butter
- 2 Egg Yolks
- ½ Teaspoon Salt
Caramel Decorations
- 200g Caster Sugar
- ¼ Teaspoon Lemon Juice
- 60ml Cold Water
- Ice
Optional: Fresh Fruit to Garnish (e.g. Strawberries).
Step 1: Preparation for the Crust
- Gather the supplies necessary.
- Use the cooking spray / extra butter to grease a 9-inch spring-form pan.
Step 2: Crushing the Cookies
- Take the Oreos, and using the back of a butter knife, scrape off the filling.
- Put the filling-less cookies into a bag.
- Using a rolling pin, crush the cookies until the pieces are between the size of peas and breadcrumbs.
- Pour the crumbs into a small bowl.
Step 3: Melting the Butter
- Melt the butter - this can be done in a microwave, or using a bain marie.
Step 4: Mixing Oreos and Butter
- Pour the melted butter into the Oreo bowl and stir until it has an equal consistency.
Step 5: Making the Base
- Pour the crust mixture into the bottom of the spring-form pan.
- Use a spatula to flatten and cover the entire bottom of the pan, but not the sides.
Step 6: Preparation for the Brownie Layer
- Preheat oven to 180°C / 350°F.
Step 7: Melt Butter and Chocolate
- Melt the butter and chocolate in a bain marie.
- Meanwhile, continue through the recipe.
Step 8: Mixing Dry Ingredients
- Combine white sugar, brown sugar, vanilla and salt in a large bowl.
Step 9: Adding the Eggs
- Mix in the eggs.
- Stir mixture until light and foamy.
Step 10: Mixing Chocolate/Butter and Mixture
- Once the chocolate/butter mixture is fully melted, remove from heat and allow to cool for a few minutes.
- Pour the chocolate/butter into the other mixture.
Step 11: Add the Flour
- Add the flour into the mixture.
- Stir until the flour is dissolved.
Step 12: Pour Into Pan
- Use a spatula to pour the mixture onto the crust in the spring-form pan.
Step 13: Bake the Brownie
- Put the pan into the oven.
- Bake until a skewer/toothpick halfway between the edge and centre comes out clean (about 45-60 minutes).
- Leave to cool before continuing.
Step 14: Preparation for the Chocolate Pudding Layer
- Gather the necessary supplies.
- Put a large bowl of cold water into a fridge.
Step 15: Dry Ingredients
- Put the flour, salt, cocoa powder and sugar into a small saucepan.
- Stir together until a uniform colour is reached.
Step 16: Wet Ingredients
- Add the egg yolks and a few tablespoons of milk to the powder and stir until a thick paste is formed.
- Add the remainder of the milk and sir until mostly smooth.
Step 17: Cook the Pudding
- Put the mixture onto a stove at medium heat.
- Stir the mixture until the mixture thickens and bubbles (about 10 minutes).
Step 18: Add the Butter and Vanilla
- Stir in the butter until it is melted.
- Stir in the vanilla.
Step 19: Adding the Pudding
- Take the now cool spring-form pan and put it on a plate.
- Pour the pudding onto the brownie layer.
Step 20: Smooth Out the Pudding
- Use a spatula to smooth out and spread the chocolate pudding over the brownie layer.
Step 21: Set the Pudding
- Put the plate with the spring-form pan into a fridge.
- Leave to set (at least 3 hours, and up to a day).
Step 22: Preparation for the Caramel Decorations
- Gather the necessary ingredients.
- Put ice into the bowl of water that is in the fridge
Step 23: Combining Ingredients
- In a saucepan, combine the sugar, water and lemon juice.
- Stir until a consistent texture is reached.
Step 24: Cooking the Caramel
- Put the saucepan on high heat.
- Do not stir, but wait until the edges start changing colour.
- Take out the bowl of water/ice from the fridge.
- Then, swirl the pan a few times.
- Keep the caramel on the burner until it is consistently medium amber.
Step 25: Creating the Decorations
- Take the hot saucepan and plunge it into the water/ice bowl - make sure that no water enters the pan.
- Remove from the water once the sizzling has stopped and use a spoon to take the caramel and create patterns.
- Leave the decorations to cool for at least 15 minutes.
Step 26: Taking the Pie Out of the Pan
- Use a spatula and slide around the edge of the pan to seperate it from the side of the pie.
- Remove the ring from the spring-form pan.
Step 27: Completion
- Place the caramel decorations on top of the pie and serve.
- Fresh fruit can be used to garnish if desired.
- Enjoy!
