Introduction: MistaMunsta's Knex Rifle
Knex rifle. Has a range of around 40 metres(130feet).The magazine holds 7 yellow rods. Is pretty accurate and the design is super strong. The stock is very comfortable. I admit that I borrowed a couple of ideas from others. I've tried to use minimum pieces, so those who were unable to make Gorkems sniper Rilfe ect. might be able to make this. Please comment and rate.
Step 1: The Barrel
This is obviosly the barrel.It's real easy to make and shouldn't take you too long.
Step 2: Magazine
Very simple.
Step 3: The Barrel Cover
pic1-make this
pic2-make this
pic3-put it together like this
pic2-make this
Step 4: Another Part
keeps the wheel steady. i got the idea from pineapplebob.
Step 5: Put the Entire Barrel Together
This is the whole of the barrel put together.
I forgot to show a picture of the bit that stops the bullets falling out of the mag.
Pic 1- the whole barrel put together.
Pic 2- the bit you need to add.
Pic 3- " " " " " "
Pic 4-a picture
Pic 3- " " " " " "
Pic 4-a picture
Step 6: The Main Body
The body of the rifle. dont worry about any of the rubberbands or string.
Step 7: The Handle and Trigger
The handle with the trigger. This is gorkems trigger. i thought it was great so i have used it here.
Step 8: The Stock
it is built like this, because the main problem with guns that use string to cock is that the string always got caught.
Step 9: More on the Stock
it is very comfortable
Step 10: Firing Pin
Black rod and brown\orange connector. Tape to make it stronger and a rubberband to absorb some of the impact.
it obviously goes in the barrel
Step 11: Bipod
It isnt the greatest bipod. it swivells which makes it easy to aim. It is easy to clip on or off using the blue and purple connector.
pic1-what the gun looks like with the bipod.
pic2-a close up of where the bipod connects to the gun
pic3-a picture of nothing important
Step 12: Add String and Rubberbands
pic1-firing pin
pic2-cocking string
pic3-cocking string
pic4-tie the string here, like i have.
pic5-tie the string to the trigger
pic6-it goes through here.
Pic7-and goes round the wheel like this.
pic8-this is the best place to put the rubberbands as it is a strong point.
pic9-put a rubberband here. this bit creates enough friction to stop the rod in the barrel falling out the front. it also pushes the next round into the barrel
pic2-cocking string
pic3-cocking string
