Introduction: Mjolnir Foam Hammer
Materials:
Faux Leather
Gorilla tape
Elmers multi-purpose spray adhesive
Spray insulating foam
Foam primer
Rustoleum hammered paint
8-inch serrated knife
Sandpaper 60 grit and 120 grit
Broomstick
Fast drying drywall mud
Respirator
Safety goggles
Measuring tape
Ruler
Marker
Cardboard box
Wax paper
Pam
Hand saw
Shoebox
Step 1: Saw
Measure the broom handle to 16.6535 inches and draw a marker line at that point then Using the handsaw, cut along the marker line
Step 2: Pam & Wax Paper
Line the walls of the shoebox with wax paper and spray them with pam
Step 3: Handle Hole
Cut a hole in the center of your shoe box lid and place the handle inside
Step 4: Filling
Cut a few entry points to spray foam into the box and then spray it until the box is full
Step 5: Wait
Wait 24 hours
Step 6: Cutting
Remove the foam from the box and peel away all wax paper and cut foam to size
Step 7: Covering
Cover hammer in drywall mud
Step 8: Sanding
Sandpaper the drywall mud to size
Step 9: Sealing
Spray Foam Primer onto the Hammer
Step 10: Painting
Spraypaint the hammer to look metallic
Step 11: Measuring
Cut faux leather into strips twice the length of the handle
Step 12: Gluing
Use Elmer's spray adhesive to coat the back of the leather and wrap around the handle
Step 13: Looping
Roll the remaining Faux Leather at the end of the handle tightly into a coil for loop then cut Gorilla tape into very thin strips and loop around the coil and attach back to handle
Step 14: Finished
You have your own Mjolnir to Wield Thor's Power
