Introduction: Mobile Bicycle Repair Place
At work it is not obvious to use good bicycle tools. Some do not put it in the same place in the work case, often the material just disappears.
Until today thanks to the use of the mobile bicycle repair place!
All the necessary material to recover bicycles hangs on a steel cable. Simple: take tools, pull out a cable, carry out editing!
Due to the built -in pulley system, the steel cable rolls back and the tool automatically hangs in its right place!
The whole is on sturdy wheels and is movable everywhere!
- different pieces of quality tools to work on bicycles
- sturdy wooden sheet material 18mm
- Steel cable 4mm thick
- Roll scaffolding compact
- different mounting material: pulleys, eye pipes, screws
- For Conterweight: nuts M28
- etc...
Step 1:
Make a cupboard that fits in a compact mobile scaffolding.
Step 2:
Provide a beam on the back to which you attach the steel cables and use the principle of the loose pulley.
Number of cables = number of pieces of tools
Step 3:
As extra weight under the loose pulley, 2 heavy nuts M28 were used each time. Made together with straps.
Best closing for safety afterwards
Step 4:
Insert the cables through the rear wall and attach to the tools with clamps
Step 5:
Everything neatly together
You can close the cupboard with, for example, a bracket lock
And now repair action!
