Introduction: Mobile Controlled Car
I made a Mobile Phone Controlled Car.
I have designed the Android Mobile Application. This car can be controlled by mobile application. It is a project which can be used by Engineering students or school going students to show it to their teachers.
Step 1: Gather Components
Arduino Uno
L293D motor driver module
DC motors with wheels x 4
Bluetooth module
18650 batteries x 2
Switch
Jumper wires
Acrylic sheet
Red leds x 2
White leds x 2
Cardboard
Step 2: Make Car
Place all 4 dc motors on the car and stick wheels to it.
Step 3: Place Arduino and L293D Motor Driver
Place arduino and L293d motor driver on the car
Step 4: Stick Led Lights
Stick red led lights to back
Stick white led lights to the front
Step 5: Download Arduino Ide and Upload Code
Upload the Arduino code shown below....
// https://www.youtube.com/channel/UCaXI2PcsTlH5g0et67kdD6g //
// Smartphone controlled Robot // // By MOHD SOHAIL //
#include
AF_DCMotor motor1(1, MOTOR12_1KHZ); AF_DCMotor motor2(2, MOTOR12_1KHZ); AF_DCMotor motor3(3, MOTOR34_1KHZ); AF_DCMotor motor4(4, MOTOR34_1KHZ);
int whiteled = A5; int redled = A4;
char command;
void setup() { Serial.begin(9600); pinMode(whiteled, OUTPUT); pinMode(redled, OUTPUT); }
void loop(){ if(Serial.available() > 0){ command = Serial.read(); Stop();
switch(command){ case 'F': forward(); break; case 'B': back(); break; case 'L': left(); break; case 'R': right(); break; case 'S': Stop(); break; case 'a': on(); break; case 'b': off(); break; } } }
void forward() { motor1.setSpeed(150); //Define maximum velocity motor1.run(FORWARD); //rotate the motor clockwise motor2.setSpeed(150); //Define maximum velocity motor2.run(FORWARD); //rotate the motor clockwise motor3.setSpeed(150);//Define maximum velocity motor3.run(FORWARD); //rotate the motor clockwise motor4.setSpeed(150);//Define maximum velocity motor4.run(FORWARD); digitalWrite(redled , LOW);//rotate the motor clockwise }
void back() { motor1.setSpeed(150); //Define maximum velocity motor1.run(BACKWARD); //rotate the motor anti-clockwise motor2.setSpeed(150); //Define maximum velocity motor2.run(BACKWARD); //rotate the motor anti-clockwise motor3.setSpeed(150); //Define maximum velocity motor3.run(BACKWARD); //rotate the motor anti-clockwise motor4.setSpeed(150); //Define maximum velocity motor4.run(BACKWARD); //rotate the motor anti-clockwise digitalWrite(redled , HIGH); }
void left() { motor1.setSpeed(150); //Define maximum velocity motor1.run(BACKWARD); //rotate the motor anti-clockwise motor2.setSpeed(150); //Define maximum velocity motor2.run(BACKWARD); //rotate the motor anti-clockwise motor3.setSpeed(150); //Define maximum velocity motor3.run(FORWARD); //rotate the motor clockwise motor4.setSpeed(150); //Define maximum velocity motor4.run(FORWARD); //rotate the motor clockwise digitalWrite(redled , LOW); }
void right() { motor1.setSpeed(150); //Define maximum velocity motor1.run(FORWARD); //rotate the motor clockwise motor2.setSpeed(150); //Define maximum velocity motor2.run(FORWARD); //rotate the motor clockwise motor3.setSpeed(150); //Define maximum velocity motor3.run(BACKWARD); //rotate the motor anti-clockwise motor4.setSpeed(150); //Define maximum velocity motor4.run(BACKWARD); //rotate the motor anti-clockwise digitalWrite(redled , LOW); }
void Stop() { motor1.setSpeed(0); //Define minimum velocity motor1.run(RELEASE); //stop the motor when release the button motor2.setSpeed(0); //Define minimum velocity motor2.run(RELEASE); //rotate the motor clockwise motor3.setSpeed(0); //Define minimum velocity motor3.run(RELEASE); //stop the motor when release the button motor4.setSpeed(0); //Define minimum velocity motor4.run(RELEASE); //stop the motor when release the button digitalWrite(redled , LOW); }
void on() { digitalWrite(whiteled , HIGH); }
void off() { digitalWrite(whiteled , LOW); }
Step 6: Do Connections From Circuit Diagram
Circuit Diagram
Step 7: Install Mobile App From Link
Mobile application download code...
https://drive.google.com/file/d/1733wgAgGncZI_EUYwARYVEgmNIOC_0EB/view?usp=sharing
Step 8: Connect HC05 From Mobile
Open Bluetooth of mobile and connect to HC 05.
Password must be 0000 or 1234
Now open the application and connect to HC05 and run the car..
Step 9: Final Subscribe the Channel :-)
If your project is done
Do subscribe the channel
