Introduction: Mobile Phone Stand
Hi friends,
In this instructable, I'm going to show you how to create a mobile phone table stand at the home.
This phone stand is adjustable to hold the phone in most directions for general use. The stand can be used for;.
* As the charging holder/stand.
* Watching Movies
* On desk holder
* Mobile app developer stand
* As a mobile shop phone display
You will need
01- PVC Pipe 4" x 20"
02- PVC Pipe 1/2" x 10"
03- Glue
04- Two buttons
Tools and equipment
01- Heat gun or gas stove
02- Cutter / Knife
03- Pencil
04- Marker pen
05- Tile
06- Sandpapers
07- Soldering iron with flat bit
Step 1: Prepare PVC Sheets From the Pipe - 01
- Get the 4" PVC pipe, and cut it
- Prepare heat gun flat nozzle (You use a gas stove or other heating source if you haven't a geat gun)
- Heat the PVC pipe gently
Step 2: Prepare PVC Sheets From the Pipe - 02
*Get the tile, and flatten the heated PVC pipe
*Apply weight/pressure for about 1-2 minutes
*You may need to heat several times and apply the heat to get a better flat surface.
Step 3: Cut Parts
*Cut two main parts for the stand
*Use sandpapers to smoothing edges
Step 4: Prepare the Rotating Axel Part
*Prepare the rotating axel part from the 1/2" PVC pipe
Step 5: Bend the Stand
*Heat and bend the stand using the heat gun and the tile.
Step 6: Mark the Axle Cut Points
*Mark both axle cut points
Step 7: Cut Holes for Axle
* Use a flat bit with soldering iron to cut two holes. You can use any other suitable tool.
* Attach the axle to the stand
Step 8: Bend the Phone Grabber
* Use the heat gun to heat the grabbers, and bend them using the pencil
Step 9: Holder Axle Support
- Mark and cut two holder axle supports
Step 10: Glue Everything
* Glue the center axle to the holder plate
* Glue supporting parts
* Glue center axle rotating part
Step 11: Mount the Holder Plate
*Mount the prepared holder plate on the stand axle.
Step 12: Finished!
* You are finished! Now you can use the created mobile phone holder for your daily life.
* You can decorate it a bit, and use it as a mobile phone display for a showroom.
* Please watch the full instructional video for more details and decoration.
* Video link: https://www.youtube.com/watch?v=-igrmUk4OFg
