Introduction: Mobile Stand Using Scrap Wood
Take two scrap wood pieces in given dimension and cut them at 60 degree angle from one end such that only half part remain there.
- Approximately 3.5x0.5x0.5 inch size scrap wood pieces.
- Wood glue
- Toothpicks
- Wooden dowel
- Wood polish
Step 1: Glue Them
Glue both pieces using any wood glue and clamp them. Let it dry for a day.
Step 2: Sand Polish and Drill Hole
Make the corners smooth and rounded using a sand paper and knife.
Drill four holes and fix tooth pick pieces.
Make a 0.5mm hole in center where the two pieces have joined.
Step 3: Make a Dowel and Polish
If not available, make a wooden dowel (pin) using a bamboo stick and make it smooth. You can also use Wooden Skewers/BBQ Sticks Seekh.
Cut them in proper length and polish the stand using any wood polish or danish oil.
Step 4: Finally Done.
Your wooden mobile stand is ready!
You can make some other designs also.
Thanks.
