Introduction: Mobile Phone Dash Mount From Scrap
Make a dashboard mount for your mobile phone from and old harddrive and a tuna can
Step 1: Things You Will Need
You will need:
1 some side cutters
2 some scissors
3 an old hard drive
4 a tin food can (I used a tuna can because it had flat sides)
5 tools to dissasemble the harddrive (varies with the type of harddrive)
1 some side cutters
2 some scissors
3 an old hard drive
Step 2: Open Up Your Hard Drive and Recover the Magnet
If you open the harddrive you will usually find a couple of powerful magnets which make up part of the head drive motor.
The magnets are usually glued onto a peice of steel with a couple of holes in it, if you have a modern car you may want to leave the plate on and use the holes to screw or cable tie the magnet to your dash
Step 3: Fit the Magnet to Your Dash
This was very esy for me as my Landy (1959 Series II SWB petrol) has a steel rail at head height which was perfect just to stick the magnet to.
You may neet to be a bit inventive using cable ties, double sided sticky foam etc.
Make sure the position does not interfere with driving, the cables are easy to get tangled up in! (so experience has taught me)
Step 4: Cut a Piece of Steel to Fit Inside Your Phones Case
My old phone had enough steel in it to stick to the magnet without any steel but my latest phone is made entirely of plastic!
Cut a peice of steel from the side of the can using scissors, you will probably need the sidecutters to get through the rim, or else use a can opener to take the rim off.
As you can see from the photos I have shaped the metal to press between two plasic lugs on the inside of my phones rear case. If your phone won't do this you might need a little double sided tape to secure the metal.
Step 5: And Use!
The phone should now sit securely on the magnet, if the steel in the phone is thick enough you should even be able to dial without holding the phone (my last phone would)
Plug it in to charge and attach your headset (or turn on bluetooth if you are flash and with the times)
Step 6: Don't Throw Away the Hardrive Bits!
I have found the board on the back of most hard drives to be a usefull source of scavangeable components (EEPROMS, RAM, passives etc.) In fact if you look at my synchro record project you will see scavanged capacitors on the board.
The case when emptied will also make a usefull electromagnetically shielded project case.
