Introduction: Model Jet Car - Carbon Fiber!!
This was supposed to be a short and easy project for my son to enjoy. Well... Go big or go home! We made a Carbon Fiber jet car that takes an Estes Model Rocket with parachute if you want.
You will need:
Foam Board
Paper
Elmers Glue and water for a 50/50 mixture
Small paintbrush
Fiberglass and/or Carbon fiber cloth
Epoxy Resin
A toy car medium sized for parts - body, axles and wheels
Glue gun
Airbrush, paint and stencils
Micro bearings
Exacto knife
Scissors
Small rotary tool to cut small parts
Estes Model Rocket Engines
Step 1:
First was the design. After a little research on land speed record holding life size jet cars, I found a current record holding design from Australia. I modified it slightly as you will see with the drag racing spoiler I made for it.
Step 2:
Step two was cutting the design onto foam board and making a wire frame using paper to keep the weight down. This was a similar process to fuselage builds of planes or wooden ships. This also gave it a rough shape that would have to be smoothed out later.
Step 3:
In this next step I finished the paper wire frame with flat paper "panels" to cover the holes. After, the (50/50) water/glue mixture I made dried, I glassed one layer of fiberglass.
Step 4:
My son had a car that he broke so I took it apart and cut some of the body to use on the body of the jet car. I also used the base frame of the toy car to align the back wheels on in a step you will see later. Once the glass cured, I painted it black.
Step 5:
Step five was adding one layer of carbon fiber to add strength and also for the "look."
Step 6:
Here I needed to create a carbon tube that would hold the jet engine and a second tube that would either exhaust the gas build up inside the body or where the parachute will be deployed from.
Step 7:
Step seven I made some details that will help with aerodynamics and create a bold look. I'm not sure if the spoiler actually helps it grip the ground, but before I lit it up the first time I wasn't sure if the thrust would lift the jet car.
Step 8:
Alignment is key to make this thing go in a straight line. Later I found out that the surface had to be as smooth as possible. To decrease friction I purchased some micro bearings.
Step 9:
The finishing steps included some airbrushing, cutting some toy skulls up to add to the rear, a front spoiler (later removed), and epoxy finish to coat.
Step 10:
The finished product photos didn't have the parachute.
