Model in a Block or Clear Glue (FAILED)
Intro: Model in a Block or Clear Glue (FAILED)
This is my failed attempt at trialing a technique for setting a model in clear plastic (or glue)
WARNING: this instructable uses hot, molten glue, contact with this will cause horrific burns.
STEP 1: Get Started
You will need:
- a model
- clear hot melt glue sticks
- a melting pot
- a stove top
Before you get going, shock the model fits inside the pot!
Then set your hob to a mid heat and put on the pot within the hot melt glue sticks.
Allow them to melt slowly, remember all materials have a flash point (a temperature at which the burst into flames) so be careful, we don't want to be making explanations to the local fire department!
- a model
- a melting pot
- a stove top
STEP 2:
When the glue is fully melted, use a small stick (matchstick) to tease out as many air bubbles as possible.
Please remember this glue is molten and will burn your skin!
Drop the model as centrally as possible and assist it to sink with your stick, again be careful not to burn yourself and remove the bubbles created by the model.
Remove the pot the cool and set
STEP 3: Failure
Hmmm, I came back to my model, never mind the bubbles (this was the trial run remember) but my clear glue set white and my model hidden.
This is where I need advice, I want to encase models in solid, clear material. Ultimately I would like to make blown apart models, like a CAD drawing, suspend them with fishing line and encase them. This way you get a physical 3D blown apart model you can handle and view from any angle.
My mod ideas are:
-solid models
-deconstructed lego models
-dismantled technologies like CD or hard drives
My mod ideas are:
-solid models
14 Comments
jtobako 7 years ago
Epoxy, but thin stuff so you don't have to deal with bubbles, which means you do have to worry about holding it in place so it doesn't sink.
There is a 'fake water' epoxy that is clear. Usually sold in big craft stores for floral displays.
I saw a display of a beer bottle in the process of exploding (steampunk time stop experiment). He used clear gel beads and water, carefully placing each piece as he filled the jar.
Left-field Designs 7 years ago
Kcuboo 7 years ago
Kcuboo 7 years ago
Kcuboo 7 years ago
Alex in NZ 7 years ago
Thank you for having the courage to post the failure. You may have saved several people from making similar mistakes.
Good luck if you make another attempt and please do post that.
nckenergy 7 years ago
First off, the hot glue sticks aren't clear, so how could they be after heating?
plundquist1 7 years ago
dj_nme 7 years ago
I think you'll probably have to use 2-part casting resin to do this, as I think hot-melt only comes in translucent white(ish) and various solid colours.
Yes I think you are right, the lady in the shop said it dried clear but that's true of most glues when you apply them in a thin layer
Thanks for the tip, is it expensive do you know?
