Introduction: Modern Steel Fire Pit
In this Instructable I'll show you how I made this modern steel fire pit. It was my first full metal project (most of my others include woodworking).
Be sure to watch the video above, and if you like it please subscribe to my YouTube channel! And if you like the Instructable please vote for me for the Metalworking Contest at the end of the post!
1/8" mild steel plate
1/8" mild steel square tube
1/8" mild steel bar
Step 1: Gather Materials and Supplies
The materials for the fire pit are pretty basic. Just some 1/8" plate steel and square tube. I also used some round bar for a grate.
Tools/Consumables Used:
Diablo Steel Demon 7-¼” Metal Blade - http://bit.ly/2J7geDW
Diablo Steel Demon 14” Metal Blade - http://bit.ly/2RM9gs7
Lincoln 140 MP Welder - http://bit.ly/31Z93Xb
Slow Speed Chop Saw - http://bit.ly/31Z93Xb
Large Right Angle Magnets - http://bit.ly/31Z93Xb
Small Right Angle Magnets - http://bit.ly/31Z93Xb
Edge guide - http://bit.ly/31Z93Xb
Gorilla Grip Gloves - http://bit.ly/31Z93Xb
Supplies:
1/8" plate steel
1/8" square tube
1/8" round bar
Step 2: Cut Metal Plate to Size
I started by cutting the plate steel down to size with a metal blade in my circ saw. The design is very basic with a 24x24" top opening.
I cut two sides to 10x24 and left them rectangular.
Then I cut the other two sides with 45 degree angles on them. This would give me the sloping sides
Lastly I cut a piece to fill in the bottom.
Step 3: Cut Square Tube for Legs
I cut the square tube to size for an A-frame style leg. The angle on the legs splayed out 15 degrees.
I made the cuts on my slow speed chop saw and matched all the angles for clean corners with no open ends except the bottom.
Step 4: Weld the Fire Bowl & Grate
I used some setup magnets to hold the sides together and welded them with 0.25 MIG wire.
I worked my way around the bowl until I had all the sides attached and then laid in and attached the bottom.
To hold the wood off the bottom I welded up a grate from 1/8" bar. This sits on some small triangular standoffs I welded to the bottom of the fire bowl
Step 5: Weld the Base and Attach to Fire Bowl
Next up I welded the base together using the magnets to hold everything in place.
I added two stretchers between the leg assemblies for some extra support and strength.
Then I welded the base to the fire bowl using a set of wood blocks to hold it where I wanted it.
Step 6: Finish Up
I added some drainage holes in the fire pit to get rid of any standing water and called it a wrap!
Be sure to watch the video above for more details, and if you like it please subscribe to my YouTube channel!
And if you like the Instructable please vote for me for the Metalworking Contest below!
