Introduction: Modern Step Stool for Kids!
This Modern Step Stool was a lot of fun to build. This woodworking project features a wrap-around grain pattern that pushes the piece to the next level. I designed the step stool for my kid, who was three at the time. I got tired of seeing the same step stool designs and wanted to do something a little different. The miters on this piece were tricky to figure out, but the result is quite interesting.
It uses compound miters and bevels to create a beautiful yet sturdy piece of furniture. Though I wouldn't recommend anyone over 75 pounds step on it as it is designed for kids. I had seen many woodworking project videos for a step stool, but nothing had a look I wanted. Thus I created this more modern piece.
I built the step stool using walnut hardwood and reinforced the joints with dominos. So I know it will be plenty strong for my three-year-old son for years to come.
If you want the plans for this project, I have them linked below. I hope you enjoy the build and if you have any questions for me, please leave a comment below.
- 4/4 lumber of choice
- Table Saw
- Bandsaw
- Miter Gauge
- Crosscut Sled
- Tenon Sled
- Sand Paper
- Sander
- Dominoes or Dowels
- Glue
- Painter's Tape
- Finish of Choice
Step 1: Mill the Lumber
- Mill 4/4 lumber at the jointer.
- Flatten one face and one edge of the rough cut lumber at a jointer.
- Place the flattened side down and plane the board to 3/4"
Step 2: Horizontal Pieces: Cut Boards to Rough Length and Width
- At the table saw, place the board's jointed edge against the fence.
- Rip down both boards to 4".
- You can make these boards wider for a larger stool if you wish.
- Using a crosscut sled, cut the boards down to rough length.
Step 3: Horizontal Pieces: Cut the Miters
- Set table saw to 48 degrees.
- Then use a miter gauge set to 60 degrees to cut the compound miters for the horizontal pieces.
- Mark out the final length for the miters.
- Use a miter gauge to cut the final length.
Step 4: Make the Vertical Pieces
- Mark out the final length for the vertical pieces.
- Using a crosscut sled, creep up on the line.
- Cut a 42 degree angle by clamping the piece to a tenon sled and slowly make the cut.
- At the crosscut sled, sneak up on the cuts for the vertical boards.
- Now is a good time to do a dry assembly of your pieces!
Step 5: Cut the Bevels
- Tilt the blade to 66 degrees.
- Cut the bevels for the horizontal pieces.
Step 6: Mark Out and Add Dominoes
- Tape the joints together and mark out the domino placement for the vertical pieces.
- Set the fence angle of the domino to match the miter angle and then plunge the holes for the floating tenons.
- At the bandsaw, tilt the table to match the 82 degree angle of the vertical taper on the legs.
- Then creep up on the cut.
- For the bottom step; again, mark out the placement for the dominoes and plunge the mortises.
Step 7: Glue Up and Final Final Cuts
- Glue up the first 2 pieces for the bottom step.
- Cut the dominoes in half to allow for the angled step to sit flush.
- At the bandsaw, trim the overhang of the bottom step flush.
- Sand everything up to 180 grit.
- At the table saw, cut the 82 degree angle into the bottom of the vertical leg that would sit on the floor.
- Tape off the inside of the miter joints to prevent squeeze out from filling the inside of the joint.
- This makes for an easier cleanup
- Use blue painters tape to clamp each joint tight
Step 8: Final Sanding and Finishing
- Using 180 grit sandpaper break all the hard edges on the piece and cleaned up any discrepancies in the miter joints.
- Sand everything again up to 220.
- Add your finish of choice.
Let your little one enjoy their new step stool!
