Modern and New and Easier Example of Locker With Arduino Matrix Keypad 4x4
Intro: Modern and New and Easier Example of Locker With Arduino Matrix Keypad 4x4
Another example of using a LCD keypad matrix 4x4 with an I2C circuit.
STEP 1: The Schematic
This matrix keypad is made of 16 push buttons and with I2c communication, you just need 2 pins to manage it: SDA (A4 on arduino board) and SCL (A5 on arduino board).
I used a PCF8574A 16 DIP I/O I2c circuit the small schematic is given above. The address of this kind of components is 0x3C in my example (A0=0, A1=0, A2=1).
STEP 2: The State Diagram: an Easier Method
This new method is based on timers which allow you to compose the good code (made of 4 characters: CODE1 then CODE2 then CODE3 then CODE4) on the keys in the right time.
The arduino sketch includes 4 special libraries:
- SM.h
- Wire.h
- Keypad_I2C.h
- Keypad.h
I give a pack of them and the sketch. If the typed code is good, the pin 13 light ON and you need to push the key ' * ' to initialize. If the code is wrong, the pin 13 flashes.
note: I can't download today the libraries due to an internal server error. Sorry.
PROBLEM SOLVED IF YOU USE .RAR
STEP 3: Conclusion
The keys pushed must be detected on a rising edge, unless, it will not run properly.
All these components are very cheap and you will have a very catchy keyboard with few pins on the Arduino boards.
Thanx to all insteresting tutorial I found.
Happy instructable!
2 Comments
gada888 4 years ago
manu4371 4 years ago
