Introduction: Modify a Tomahawk
So I bought a mass market tomahawk the other day. I'd always wanted one, then stumbled across a website and discovered they were really affordable. About $30 shipped. And several different styles to choose from. I chose a 'Cold Steel Trail Hawk.'
It came in the mail and I was shocked at how BORING it looked. So I decided to make a few changes. And this beauty was born.
(This is my first 'ible. Hope you enjoy!)
Step 1: Raw Materials
So here is what I got in the mail. A 'hawk with a plain handle (I ordered a spare, too). With the axe head painted black. Like I said.... boring.
First step is to remove the axe head. On my model there was a small hex screw on the side of the head. I found the correct hex wrench and simply removed it entirely. With the encourangement of a wooden mallet, I was able to slide the head _down_ the handle.
Step 2: Remove Paint From the Axe Head
Careful about this stuff touching bare skin - it burns.
Once all the paint was loose, I washed it with plain ol' soap and water.
Step 3: Boil Axe Head in Vinegar
I dont have any before pics, but the axe was just a raw metal color. I boiled in plain white vinegar for 20 minutes and the head developed a black ashy patina. A word of warning here: boiling vinegar will make your whole house smell like vinegar. I didn't mind it, but my wife was pissed!
I used an old camping pot that I was retiring anyway.
Once the head was cooled down I used a regular green dish-washing scrub pad to rub down the axe head. This exposed some of the underlying brighter metal, especially around the edges of the head.
You'll also reveal the heat treating marks on the blade too.
Some other methods include using a 'bluing' or 'parkerizing' finish. Heck, you could even just paint it any ol' color you want.
Step 4: Dress Head and Handle
I also used a belt sander then some finer weights of sandpaper to reshape the cutting edge. There are numerous resources on the internet on how to get a good edge on an axe head. I didnt go for razor sharp - I got to 220 grit paper and it was plenty sharp.
There was also some 'play' in the fit between the handle and the axe head. So I sanded down the entire handle, removing what seemed to be a glossy polyuruthane coating. I then further lightly used a rasp and sand paper to make the axe handle seat better in the axe head.
A tomahawk like this does not have a pin or wedge holding the head on the handle. Instead the handle tapers wider at the top - sort of 'trapping' the head on the handle. Be careful not to take off too much material so that the head will slide off. You can see in my pics that the head sits slightly closer to the end of the handle in the finished pic, versus the original placement.
Step 5: Dressing Up the Handle
At this point, I have sanded away the factory finish off the handle. I used an off-the-shelf wood stain to get the deeper color I wanted. Two coats.
I also used a woodburning kit to draw a four directions symbol. But you could draw or carve any design you like.
I also wanted to have a lanyard hole at the end of the handle. I went to a hobby store and got some 1/4 inch outer diameter brass tubing. I drilled a 1/4 inch hole, cut a piece of tube to fit. I used a fine file and then just sandpaper to shape the brass to be flush with the handle.
Once that was all complete I used wipe on polyurathane to give it a waterproof coating. Two coats. I used a coat hanger to hand the handle while I painted it with the poly.
You could use a wide variety of treatments for the handle. There are a variety of staining techniques to add color. Ink washes, paint, etc. You could even char the handle to get a deep black. Instead of a poly coating, you could also treat the handle with various penetrating oils.
Step 6: Put It All Together.
Once the poly is good and cured it's time to attach the axe head to the handle. Slide the head up the handle till it start to get snug. To get a tight fit, grasp the handle directly under the axe head. Then whack the top of the handle with a rubber or wooden mallet. This will seat the head on the handle. Further use will further tighten the fit.
PS: Further mods.
At this point you could add a paracord lanyard to the handle. Lots of options and varieties there too.
I've also seen folks mod the axe head itself. You can use various files to make decorative notches on the head. I also polished the pol - the hammer face opposite the cutting edge. Many thanks to Cold Steel and the Bladeforums.com.
Thanks for your comments!! I'd love to see pics of your 'hawk!!
