Modify a Generic USB Car Charger to Charge a 3rd Gen IPod Nano
Intro: Modify a Generic USB Car Charger to Charge a 3rd Gen IPod Nano
I have a 3rd generation iPod Nano. It detects it's connected to but refuses to charge from a generic car->USB charge adapter, but I didn't fancy buying an adapter cable or yet another charger specifically for the iPod, so I modified one I already had.
There's a chance that this could work for other USB devices (maybe an iPhone too, but I don't have one), but there's also a chance that this could fry your device, car, or perhaps eat all of the cheese in the house. If you're not confident, or not competent, you probably don't want to try this. I accept no responsibility for any bad things happening.
If you're vaguely interested in stuff like this, you should probably check out ladyada's MintyBoost! kit, which helped prod me towards actually doing this.
STEP 1: Bits Needed
You shouldn't need more than the fairly standard soldering tools, a multimeter, and a couple of resistors (not shown) -- I grabbed a couple of SMT resistors from an old CDROM drive.
If you want the very simple steps without any instructions, all I did was connect a 27k Ohm resistor from V+ (Pin 1) to D- (Pin 2), then another 12k Ohm between D- and D+ (Pin 3). Dead easy.
STEP 2: Open the Charger
You need to disassemble the charger (actually you could probably do this in a USB extension cable, but I didn't want any more clutter).
Take the fuse and cap out. Then you need to split the charger open. Mine was welded together so I had to saw through both sides of the case and then lever it open. Don't cut too deep with the saw or you'll end up going through the components of the charging circuit.
STEP 3: Add the Resistors
You need to add two resistors. You should do a continuity test first to determine if your two central pins are connected to any others. If they are, you've likely got a different charger and this probably won't work.
According to the USB charging and power spec I should be able to simply short the two central pins (the data lines) and the device will detect that it's connected to a charging device and start charging.
I tried this first of all, but it didn't work (the iPod detected it had been plugged in to something, but refused to charge). I knew the iPod charged from my MintyBoost!, and after a quick look at the schematic and some playing with the multimeter, I decided it would be worthwhile adding a couple of pull-up resistors.
I don't think the values are that vital (the USB spec is quite forgiving), but I decided to try matching roughly what the MintyBoost! was giving, apart from the V+ to D- resistor, which was guesswork.
Don't forget to check that you've got the correct resistance between the pins, and that they're not connected to anything they shouldn't be!
STEP 4: Test (and Rejoice)!
After reassembly I tested the charger with a device I didn't care about -- in this case a broken DG-100 GPS datalogger -- to check nothing (useful) exploded.
Next I tried all three iPods I could get my hands on. Success!
I wrapped the charger with duct tape to complete that "finished" look.
22 Comments
Leinho 14 years ago
techboy411 12 years ago
davis65536 14 years ago
chooper1 12 years ago
davis65536 12 years ago
h00ch 14 years ago
geraldrubalcava 13 years ago
danielemur 14 years ago
I'd really be surprised if it didn't; it works for the iPhones and for every other iPod I've found.
mopk47 14 years ago
acaz93 14 years ago
endolith 14 years ago
Cell phones don't follow the USB-IF charging spec, either. I'm not sure if anything does. :)
khem2356 15 years ago
davis65536 15 years ago
gamer 15 years ago
