Introduction: Modifying 120deg Viewing Angle Infrared Rear View Camera
These cameras can be purchased from ebay for a little as $15. They are great for security cameras as they have a wide viewing angle and clear image however out of the box the camera comes with a trapezoidal grid superimposed on the video signal and the video image mirrored. These instructions will show how to disable the superimposed image and reverse the video signal.
Disable superimposed image:
First step is to expose the circuit board and locate the SOIC-8 EEPROM (Microchip 24C04A) IC as shown in figure 1. Note that this may look different for each camera. (I had 2 identical model cameras with different circuit boards)
Pin-5 is the serial data connection (SDA) which programs the trapezoidal image on startup. Use a solder iron to pull up this pin as shown in figure 1. Note, if the image is ever desired one could place a switch on these connections however the distance would be limited due to I2C standards.
At this point power the unit up to verify the superimposed image has been removed. If the image is still present check for a small bridge between the pin and the pad or try removing the pin entirely.
Reversing Video signal:
The PC1030D image sensor is actually a very feature rich sensor. The manufacturer has a built in image reversing feature by placing logic 0 or 1 on a data pin. Depending on the circuit board this pin may be accessible from the back of the board however in my case I had one that was and one that was not. The green wire in figure 1 is connected to the reversing pin and 3.3V. Some models also have an external wire for this so check the instructions before completing this step.
If you model does not already have a wire for this or it does not look exactly like the image in figure 1 you will need to access the pin directly from the PC1030D image sensor. Remove the 2 small screws that retain the lens housing. DO NOT TOUCH THE SENSOR. Oils from your skin will smear the image and attempts to clean it will result in scratches. Figure 2 shows the front of the image sensor.
Unfortunately, no discernible markings to indicate a “pin1” (which is in the middle of the chip) could be found, however the image sensor itself does help indicate pin position. Rotate the camera until the image sensor looks the same as figure 2. The orange distance measure indicates the sensor is slightly more to the right. Also, note the difference in the gold wires from the orange and green circles. Use these as road marks to orient your sensor. Once it is in the same orientation as figure 2, the pin you want is the third in from the left as indicated by the meter probe. You have two choices from this point; either carefully solder a small wire to the pin or try to locate this pin on the other side of the board using a continuity meter. If you solder to the pin, make sure to cut a very small notch out of the lens housing to make room for the wire. A fraction of a millimeter will cause the camera to be out of focus when reassembled. If the image is blurry after completion this is the likely cause. Solder the other end of the wire to the 3.3V pin.
Reassemble the lens housing using very little torque on the screws as they strip easily. Now, power the camera up and confirm operation. If the image is not reversed check the connections and make sure there are no solder bridges between the adjacent pins on the image sensor.
Additional Note:
If the camera will be hard wired and the composite connectors removed it is important to know the 3.3V voltage regulator is located in the wire as shown in figure 3.
It is disguised as a ferrite connection but inside is a linear 3.3V regulator. This may not be true for all models however take precaution before removing.
Hack It! Challenge
27 Comments
1 year ago
Good day all, I'm still trying to figure this out, I tried lifting pin 5 and it just went to gre scale, any help would be appreciated.
Reply 1 year ago
I switched to IP cameras about 8 years ago and unfortunately I no longer have these cameras to test with. I uploaded the data sheets for the eeprom and the image sensor to the project. I hope that helps and good luck!
3 years ago
It's my previous back up rear camera, work fine. Eeprom type 24C08A
First try, I removed the 5th pin, trajectory line is still there but now showing "1.0, 1.5, and 2" beside the line. I assumed it's refer to distance. Also showing "STOP" blinking at middle.
The picture become normal, not mirrored any more.
Then I removed consecutively 6, 1, 2, 3, 7, and completely removed the eeprom type 24C08A, nothing change. The line was still there plus bonus distance indicator and STOP. Normal image, not mirrored.
I tried to short the 2 pin above the eeprom (green arrow) and vioolaaaa... the line, indicator, and STOP everthing was gone.
I supposed to find it earlier wkwkwkkkk...
Reply 2 years ago
I had the same problem but if i remove pin 5 (or the eeprom) the image turns to grayscale. With those 2 small pins shorted the lines are gone so thanks for that tip
Reply 1 year ago
Hi there, which two pins did you short. This is my camera.
Reply 2 years ago
Did you already solved the grayscale problem?
Reply 2 years ago
Good day, I have the same problem, did you reconnect pin 5 and where did you short pin 2 to.
Question 2 years ago
bom dia fiz como descrito para inverter a imagem mas não inverteu o censor de imagem e opc1030nv
Question 3 years ago
nice post! a have one camera kind of similar to this but i have not gotten after the cap/ housing yet. I dont want to force it so it may brake...there are 2 smalls holes on the back but i cant see any screws, any hits ?
Answer 3 years ago
here are some pics
4 years ago on Introduction
sorry to say, but in my camera,(ac-5880, from camecho) has two of the microchips. one had 24c08a, and the other blank. disconnected pin 5 the one with24c08a, nothing. disconnected other one and camera stopped working. bummer. any advise for future.
6 years ago
Please be careful and check what exactly chip your camera has. I had 2 of these cameras both identical on the outside. They both had different circuit boards and chips. The first camera I tried lifting the pin didn't help , I completely removed the chip and it still changed nothing(it was a similar eprom chip). In the end I shorted it accidentally while checking my progress and killed it.
The second camera had a marked circuit board for the mirror and grid lines. I removed one smd resistor to stop the grid lines. For the mirrored image I had to remove the smd resistor (not easy on a tightly spaced board). This did not change it, I had to place a new resistor in the adjacent space. My smd resistors were too large so I had to solder a 10k through hole instead Then heat shrink and glue to prevent shorts. That was even less fun than removing them too start with.
Thanks to bbarenz and all the posters on instructables.
6 years ago
I have. couple of these with out any wires what can I do to get them to work do I need to make so.ethjng with a 3.3v regulator
7 years ago on Introduction
Thank you!! Worked like a charm.
8 years ago on Introduction
Here is some NEW CCD/CMOS (II), 420 lines, 656x492. OSD (On-Screen-Display) parking grid can be removed by desoldering SDA and SCL resistor (one of them or both), location is showed with GREEN arrow. Pink arrow is NC (Not-Connected) pin on board (probably VCC or GND- I did not measure voltage). RED arrow shows PIN_3 from front side where is located CCD.
OSD is removed, but I can´t find MIRROR pin. If somebody know solution ([D7]_PIN_3 don´t work!) or any other explanation please POST!
Reply 7 years ago
cmos PC7030K ver1 ?
Reply 7 years ago
Foto new ver 7030 http://radikal.ru/fp/26af258e823540e6923af44c664b3...
Where to find the datasheet?
[URL=http://www.radikal.ru]http://s010.radikal.ru/i311/1501/1f/2372d45f0979.jpg[/IMG][/URL]
YOU CAN JUST ADD A WIRE FROM PIN 3 TO NC AS PER YOUR PIC #5.. WORKED FOR ME TO REVERSE IMAGE TO GET NORMAL VIEW
Do you happen to know where to find the SPI programming guide for the CMOS sensor? It'd be great to figure out a way to overlay the time onto the image using the PIC controller.
Also, do you know of a way to dissolve the black stuff that they used for waterproofing?
Thanks!!
I haven't dug into it at all but this looks like it has the register map and protocol information. Let me know if you come up with anything that sounds like a really cool idea!
http://www.electronics123.net/amazon/datasheet/MT9...
